I have an MC9090 that is locked into the warm boot process. I have tried a number of things including Cold boot, Cold boot releasing the trigger as the battery clicks in, CLEAN BOOT AND BLANK which appeared to be successful but the unit failed to move to the WM5.0 window after completion, still warm booting. I read that a cold boot would fix but this has not worked either. My goal is to get this device upgraded to version 6.1 but I need to get into WM first. Any help would be much appreciated.
SOURCE: hi I use symbol MC9090 HHT
Download the image from Motorolla/Symbol support and put it on an SD card. Put the card in the slot underneath the keyboard. Do a cold boot and hold down the left scan button. Dock the scanner and keep holding the button. It will launch the image installer and take off on its own at which point you let go of the scan button.
Testimonial: "good"
SOURCE: i can't boot a Symbol MC9090.
She's Broken...contact your dealer or the Motorola Help Desk at 1-800-653-5350.
SOURCE: motorola MC9090 CE clean boot
with firmware mc9090 downloaded the wrong file of the monitor.
now the device is not started.
the display does not light up.
what to do?
how to return it in working condition?
SOURCE: While using my datalogic Skorpio,
If you have found a solution, can you contact me at [email protected] ?
SOURCE: Hi, unable to boot mc9090. (warmboot
909XCLEANBOOT.ZIP
This file is intended for use when a CLEAN BOOT of an MC909X WM 5.0 device is required. Unzip the contents of this device to either the root of an SD Card (and place the SD Card in your device) OR the TEMP folder. Then follow the UPDATE LOADER boot instructions below.
909XCLEANBOOTANDBLANK.ZIP
This file is intended for use when both a blank Application Folder and a CLEAN BOOT of an MC909X WM 5.0 device is required. Unzip the contents of this device to either the root of an SD Card (and place the SD Card in your device) OR the TEMP folder. Then follow the UPDATE LOADER boot instructions below.
There are two methods to perform an Update Loader Boot on MC909X:
Method 1
1. Navigate to the location where the ZIP file was unzipped
2. Tap 'StartUpdLdr.exe'
3. After 20 seconds or so, the device will perform an Update Loader boot which will cause the PKGS.LST file deposited on the device to be processed. Leave the device on A/C power during the Update Loader process
Method 2
1. Press the primary battery release on the mobile computer to partially eject the battery from the mobile
computer.
2. On an MC9090-G, while the battery is partially released, simultaneously press and release the trigger and
the Power button.
3. On an MC-909X-K or MC909X-S, while the battery is partially released, simultaneously press and release
the left scan button and the Power button.
4. Push the battery to fully re-insert it in the mobile computer. One audible click can be heard as the battery is
fully inserted.
5. The mobile computer initializes. During this time press and hold the trigger used on step #2 or step #3 (as appropriate) and place the device on A/C power either by placing it in a cradle or a CAM.
6. The device will invoke an Update Loader boot, which will cause the PKGS.LST file deposited on the device to be processed. Leave the device on A/C power during the Update Loader process.
When the device has completed the process it will return to the Windows Mobile ""Tap the screen to set up your Windows Mobile-based device" screen. At this point, if you used an SD card, please remove it from the device. If you placed the files in the TEMP folder, they will be automatically erased by the CLEAN BOOT process.
The files can be downloaded from:
https://docs.symbol.com/downloads/909XCLEANERS.zip but this didnt work for me i use another similar ones, probably its because you will need to find the properly version.
Regards
