Downloaded an app from android market then after, an error appeared on the handset the application home screen (process.com.sonyericsson.homescreen) has stopped unexpectedly. please try again. force close
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: My motorola flipout phone. Upon opening, the phone
Goto
Settings > applications > Manage Applications > Home > Clear
Data.
If this does not help , then Perhaps you have too many background apps open thats making
it crash?
I would suggest going to the market place and finding
"TasKiller" it eliminates any and all apps that may be taking up memory
from working in the background. It comes with a widget you can add to
the homescreen for one touch elimination. after it clears everything
your screen will be black and then might go to call log screen. Just hit
the home button and everything will run like normal but it will be much
lighter on the memory.
SOURCE: touchflo (process com.htc.launcher) has stopped unexplectedlu
All i did was take out my SD card and wait 15 seconds then put it back in the phone. I did not see the process com.htc.launcher error anymore.
SOURCE: I keep getting an error
Try this.
settings>applications>Manage applications>(select the "ALL" tab)>select "Market"
then "Clear data"
Download the latest market .apk file from
thegadgets.net, make sure you keep it in the root directory of SD card.
Once downloaded, install the market app with the help of apkinstaller
If still the problem persist hard reset your phone.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: The process com.android phone has
I would start with a Master Reset. That's the best place to start.
Pulling the battery doesn't really do anything but fix little problems.
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press HOME > MENU, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the HOME, END CALL/POWER, and BACK buttons. The reset process will start after a few seconds
SOURCE: I'm getting the error message
if you have installed a rom, or rooted your phone, it may not work, there is nothing to be done.
have you tried calling your voicemail directly and not through an app?
