I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
I just wanted to update this. If the Kenmore Elite HE4T washing machine has standing water in it after the cycle has finished (and the clothes had been spun completely), then it is the water inlet valve. It can eventually have a small leak, and then the water will fill back up inside the drain. This can be a really big issue if you are gone for a long time, come home and open the washer door. Water will flood your house. I replaced the water inlet valve and problem solved!
I meant, fill back up inside the drum, not drain.
SOURCE: Replacing the Door Bellow on Kenmore Elite Front Loaders
Hi. Open up the back of the dryer after unplugging it. Take a deep
breath. This is not that hard. A dryer is a very simple thing but you
need to relax and figure out what the parts are. A dryer has a very
basic parts list. The obvious I will not go into with but here goes with
the electrical in the guts of the machine. A motor to turn the drum. A
heating element. A sensor to sense high temps for safety shutoff of the
element. A blower for air. Keep in mind as you look at this that usually
power wires are black or red. You will see some wires that are attached
to a sensor and then on to the heating elements. Take a test light or
volt ohm meter and see if the high temp limit sensor is bad. This can be
a simple ten dollar one from Radio Shack. That is, it will it get
continuity through it. You may have to detach the wires on this sensor
to do this test. The sensor is usually a flattened round disc with two
leads coming out of it. Test the element same as the sensor. Take the
part where there is no continuity through them to the appliance parts
store with the model and serial number of the dryer for appropriate
parts. Maybe ten bucks. I know it sounds scary but you may learn
something and if all else fails just pickup the phone and call the
repairman. Hope this helps.
good luck
please rate thes
