SOURCE: Kyocera Mita FS-3800
hello helpless try to clean the printer from smeared tonner and the transfer. the grey print could be as a result of printing using application sofware. make sure the tonner economy mode is not active form the application software,if it was turn it off and save, then reprint.
SOURCE: kyocera printer problem
First I would recommend cleaning the printer. When you change the toner there is sheet of paper that comes with the toner cartridge that explains how to properly clean the printer. If you do not have that handy, there is a panel on the left hand side of the printer that you need to open. Once the panel is open you will see the waste toner bottle; leave it in place. Above and to the right of the waste toner bottle will be a green nob. Pull this green nob slowly in and out three or four times. This will clean the charging wire. Next underneath the green nob there should be a piece that looks like a rectangular box when you pull it out. I believe it is green as well. This is the charger grid. With each toner you should have gotten a small slate blue box with a plastic lid that has a piece of felt under the plastic lid. Remove the lid and this should slot in under the long, rectangular charger grid. Move this back and forth three or four times and than remove the slate blue box. Gently push the charger grid all the way back in and close the access panel.
If this does not fix your problem I would recommend getting service from wherever you purchased the printer as you may have damaged the drum.
Let me know if you have any further questions.
Henry
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
SOURCE: Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
FS-C5025N left cover removal.
1. Open the rear cover.
2. Open the top cover.
3. Remove the opening and closing axis from the main unit frame and then remove the top cover. It pry's out at the hinges.
4. Open the left side cover and then remove the one screw.
5. Remove the waste toner box. To remove waste toner box, press the lock lever in.
6. Remove the paper feed unit .
