MONARCH 9416 300DPI PRINTER
Seagull would likely have to provide the real help here, but it sounds like your Seagull drivers are not using the correct supply setting. If the supplies have a black mark on the back of the liner, then set your driver up as black mark. If they ONLY have a small gap between the labels, then set it up as die cut. If it has a die cut and a black mark, set them up as black mark.
It is also possible that your sensor is dirty, damaged, or covered up so that the printer cannot see the supplies. If you're not using Monarch/Paxar/Avery Dennison supplies, then the index mark (die cut or black mark) may not be to the printer's specification and it just doesn't know when to start and stop on a label.
