Televison & Video Logo
MK STAN Posted on Aug 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV DOES NOT TURN ON
DOES NOT TURN ON - WAS FINE WHEN SHUT OFF - OTHER ITEMS IN POWER STRIP WORK FINE
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 23, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292354
Points
3377
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service
technician, since the back cover has to be opened for investigation/rectification.
My lg 47ln5400 led lights appear to have failed. Should I replace the power supply, or just the led strips?
If everything else seems to be working fine, it’s probably not a power supply failure. That usually results in the TV not turning on at all, or shutting off completely.
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Why do I lose my recording schedule when I turn TV off? If TV is on Humax records perfectly.
Do you have a power strip or surge protector that recognizes when the power is disabled to the primary item, it automatically disables power to all other items? Easy way to check is to turn tv off and look for lights on other items plugged into surge protector.
MY TV DOES NOT HAVE POWER - SK32H240S HD TV
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
My computer will not start up, the LED light on the power unit will not come on. It was working fine. I shut it down so that i could connect it to my TV when i plugged it back in...nothing...please help...
Look on the back of your PC. Is there a switch with a I and O on it? Flip it to O and back to I and try to turn your power back on.
If you are plugged into a power strip you may want to try cycling the power on the strip as well.
1helpful
2answers
MY Sylvania LC321ss9 TV just shut off today!
It means your power supply went out. I had a sony with the same symptons and it cost 140 to fix it.
3helpful
Tv shut off, and wont turn on. It flashes when you press the power button. NO clue at what is wrong.
is the tv on a power strip? unplug the tv from the power strip or wall outlet wait one minute then plug back into the wall outlet and not a power strip. TV should power back on.
2answers
Power light doesn't shut off.
You're right. It's not only a led problem. Efective. the tv doesn't shutt off due to defective relay S901 in primary power supply. It's a 5 volts ordinary relay, replace it and it'll be fine.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
