Re: how can i get my password for my wifi security
Default username and password is "admin" and "password" .But it may differ brand to brand.You should refer to your wireless router setup manual for more information.
Using web browser enter the default ip of the linksys device. Make sure a port on the router is connected to your PC. Also ensure you configure the PC is on same subnet as your router. Login with the default credentials. This should take you to the router interface where you can set up SSID and security for your WIFI
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPhone, invoice and prove of your identity (Passport) to the Apple store and hope they will unlock your iPhone. With iOS7 Apple made a very good security system. And while setting up the iPhone and the security, you are warned several times what to do to make sure you and only you could enter the system. Whatever you is told there is no bypass for the Apple security system.Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Connecting to iTunes, only works if you had it installed on your computer and made a backup on the PC. If you know the password belonging to the Apple ID o the screen, you could try entering that.
Or perhaps you try this site?
If you don't know the secure settings of your own router, the only thing you can do is login as an Admin, and reset the thing. Then setup everything from scratch. Don't forget, all other devices that still have the "old" password, need to know the new password and the settings, to be able to connect again, after a reset.
Check to make sure you have the correct wifi password and that other devices can connect to the same wifi using that password. Power cycle your router. If those dont work might have to try changing the Wifi security encryption type to WPA or WPA2. Would need to login into your router to do this.
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
If you're talking about the Security Code/Password that you need to access a WiFi connection, that passcode is set by whoever set up the Login requirements on the router itself. You have to get that password from that person or the WiFi Router Admin page (if it's your personal WiFi at your home) If it's a Modem/WiFi unit from your Internet Service Provider (cable company), then you should contact them for the password (if they were the people who set up the password).
How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network You have lost or forgotten the password for the router, access point or other network device You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password. The default username is admin, the default password is password. From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings Note: On some routers this option will be under BASIC > Wireless. From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network. If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network. If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended) Reset and Restore a NETGEAR device to Factory Default Settings Default Password for NETGEAR devices
login to your router from a browser to 192.168.1.1 the default login is blank password is admin if you have not changed it. go to wireless. then to wireless security. select wpa/wpa2. type in a passphase. any wireless devices will need this password/passphase to connect to your wifi network.
