I have a Digimax L70 Digital Camera. I am wanting to use an 8GB SDHC card, I previously used a 1GM SDHC both Scandisk. I have formatted the card on a computer so I know there is nothing on it. When I insert this into the camera its gives me 'card error' message, then asked me to format. I chose YES, its starts to process then the camera just shuts down.
SOURCE: Format error
I don't believe the camera can handle a card of that size. I believe the camera only supports up to 512MB cards, anything above that is not guaranteed.
Samsung Specs
SOURCE: I have a scandisk sdhc 8gb memory card for my
Sometimes this happens. Sometimes the speed rating on the memory card doesn't match your camera. Most people think all SD cards are the same. I assume you have the right card, but if you're unsure, then be sure to check to be sure. Another problem is that if someone tries to format the card in something other than your camera, it messes up the format on the card and it becomes incompatible with your camera. Sometimes you get a bad card that the retailer recycled because it was a return or maybe someone sold it to you on eBay. These problems happen. You will have to get a new card and make sure everything else it alright with your camera and card reader.
SOURCE: I just bought a new
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Testimonial: "Thanks, I didn't know that! Now I'm just annoyed at the store who sold me the 8GB memory card. Guess I'll have to save that one for later."
SOURCE: Samsung digimax L70, wont read any SD card, have
Is the card properly inserted, try to check recheck and double check. cameras some times, give the guidance as a computer. it might be the card you got is not original, or was a product of a fake company. By the way how is the forecus of the camera. If you install the card in a computer is there anything appearing, in most cases there are people who temper with the genuin labels and most systems nowadays they are computerised to differantiate between the original and the fake products.
Welcome BeDeche.
SOURCE: Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
