Question about Fossil Sport University of Texas LI2084 Wrist Watch
Cannot get the cover back on Fossil watch after changing battery
We were able to snap off the back and replace the battery but now can't get the cover back on.
  • 2,338 Answers
First open your bracelet. Then align groove in caseback with crown and press that side lightly into the case. Then using both hands(one from dial side, another from back) press as strong as you can.
If this do not work:
Get mens leather belt and place it on flat surface(table top). Lay the watch face down on that belt. Again adjust caseback as before and using your weight push caseback down with both hands.
NEVER use hammer or similar.
If none of these works- go and see your nearest watchmaker.
Posted on Dec 21, 2008
  • roshansh
    roshansh Sep 16, 2012
    The leather belt method worked for me. Thanks a lot for the suggestion. To give you an idea of the pressure I had to apply though, I had to press the watch sandwiched between the leather belt with the heel of my feet and gradually shift my body weight to it until I heard it snap in place.I am about 160 lbs.
That gave me a pointer , it didn't work for me but instead i put the watch face into the leather belt then used a screw down clamp and slowly tighted it until the back clicked into place , many thanks for the ideas
Posted on Jan 12, 2009
I used to work for the Fossil company for several years. This is the problem..NEVER replace the watch battery yourself. Why not you ask? There are tools that are made especially for taking the back off of the watch and putting it back on. Also, when the back of the watch is taken off, silicone is used to put a seal along the case and caseback, this is done to "re-seal" the watch so that water does not enter your watch. If you do it yourself you also void your warranty...you can either send in your watch back to the company or take it to your nearest Fossil location.
Posted on Jan 26, 2009
  • Anonymous Jan 16, 2016
    The store I bought my watch from no longer replaces the battery and said to replace it my self. Why you ask....because too many watches were breaking and the store then had to replace them! Who has time to send it back to the factory for battery replacement? I don't!
    New Friend:
I used a belt and put it in a vise!! heard a "pop" - I thought the watch face broke, but it was the back snapping back on. I may not try this again.....
Posted on Oct 13, 2012
    Master:
  • 413 Answers
Not only Fossil watches, but all "snap" on backs are replaced using a watch press. Small handheld vices work too. A C-clamp will work but be sure to protect the crystal and turn slowly! A distinct "snap!" will tell you when it is back in position. Check your local hardware...
Posted on Dec 22, 2014
2 Suggested Answers
6ya staff
SOURCE:
riflemenx
SOURCE: Fossil ES1592
watch press
Posted on Jun 19, 2008
How do u open back to fix an fossil black 5 atm fs-4351 hand watch
Jerry, If its smooth on the back cover, you have to pry it off carefully. Get a magnifying glass and look around the cover edge, there should be a small under cut. Pry at this point with a penknife blade or similar. If the cover has 6 or 8 small indentations in it then it likely unscrews but you may still need to see a watch shop for the tool to unscrew it.
Fossil watches have a 2 year warranty so if its inside this, take it to a dealer.
Nov 03, 2014 | Fossil Watches
I want to change out batteries
1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
THANK YOU FOR VISITING FIXYA
Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
Fossil ch2360 can not figuare out how to get to the battery
mcdevito75 here, Most Fossil Watches have a press fit back cover. First locate ant tab, or indentation that is on the back cover linning up with the case itself, Carefully use a steak knife under that tab or in the indentation, slot in the cover abd pry up. From there you may need a jewlers screwdriver to loosen the battery hold down plate to remove the battery. BEST BET, look for a small watch repair shop in your area to change the battery.
Jul 31, 2010 | Fossil Watches
I have found a fossil watch model BG-2103. I cannot get the back off to change the battery, can you tell me how to get the back off and how much this watch cost.
mcdevito75 here, Look for any Notch in the cover that match a notch in the case, use a knife with a sharp blade and place the knife in the notch and with a slight twisting motion the cover should pop off. Depending on the age of the watch and the functions cost could be anywhere betwwen $25.00----$60.00 Fossil watches are also collectables.
Jun 19, 2010 | Fossil BQ9184 Wrist Watch
How do you remove the back of a Fossil watch to change the battery?
good morning ! to remove the case back of your fossil watch,just snap the case back use the knife to do that ! but if your fossil watch is waterfroof design you need to use the wrench opener for treaded watch case back ! good luck ! god bless !...
Sep 02, 2008 | Fossil Watches
Need to change the battery on my fossil watch but can't seem to remove the back of the watch to do so
good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
Aug 27, 2008 | Fossil Watches
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Fossil Sport University of Texas LI2084 Wrist Watch Logo
25,219 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
Ray Murphy
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
