GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
Ed Franklin Posted on Aug 23, 2012
Anti freeze kit #wr49x10044 - GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
What can be accessed without pullin the engine..?
Howdey howdey...
Sounds like a long and interesting conversation... on a job you have yet to begin... looks to be 10 "plugs" in all... 6 block & 4 head sized for your engine: Yes accessable... but pretty difficult
KIA 1996 SPORTAGE 2.0L L4 DOHC Expansion Plug / Set.
rockauto and autozone links will be added below)
Informational purposes:
Freeze, Fost and Expansion plugs although popularly know by such names are merely SOFT or CASTING plugs...(holes that are used to clean out the "CASTING MATERIAL" from the manufacturing process.
They were never intended to be any kind of CLEVER pressure release for DARING & COURAGEOUS in our midst... who REFUSE to use anti-freeze. There is absolutely no GUARANTEE
the block HAS NOT BEEN CRACKED or RUINED by freezing.
If ice forced out the plug(s)... you MIGHT get by... replacing one but if they are corroded... they tend to all corrode... Corrosion and electrolysis are not indiscriminate... They will destroy everything. Yet another TRAVESTY that could have been prevented with fresh, clean anti-freeze.
Pulling the engine is the most efficient way to do that job.
For the world of folks that WANT to try to get by... there are rubber
plugs that can be used in lieu of the proper CASTING PLUGS.
Check out the plug removal tool... and the BOLT TIGHTENING RUBBER PLUGS shown on the URL (immediately below).
Hope this helps!
More Information for DORMAN 570010
Freeze Plug Kit at AutoZone com Best Freeze Plug Kit Products for Cars...
2answers
My rmz450 2006 overheats.
try running with just water. Anti freeze lowers the boiling point while raising the freezing point.
Winterize vcross 365 fifth wheel
I think you have posted this several times so I wanted to add this.
The best thing is to have a dealer do it. You need to know if you have by-pass kits installed, depending on what you have for storage tanks they need to be drained, RV non-toxic anti-freeze needs to be added to plumbing and flushed through, water lines should be blown out along with draining so if there is a place where the water was level it gets forced out.
Here is a quick info for a skyline, but it really depends on what you have for plumbing.
Purchase 4-6 gallons of RV approved, non-toxic anti-freeze.
2. Drain all tanks, fresh water and sewage tanks.
3. Turn water heater by-pass valves to by-pass position. (The by pass valves are located near the
water heater incoming lines - an access panel may have to be removed depending upon the
model.)
4. Drain water heater.
5. If installed, remove water filter from assembly and discard. Install diverter if included.
6. Pour an amount of RV non-toxic anti-freeze into the fresh water tank to fill the tank above
minimum water pump operating level. (Use of a long funnel may be helpful) Add more, if
necessary, during procedure.
7. Turn on pump switch and open the cold water side of all faucet fixtures. Leave open until the
anti-freeze comes out (generally, pink in color). Repeat for hot water side.
8. Flush toilet until anti-freeze begins to flow into the bowl and then pour one gallon of anti-freeze
down the toilet to winterize the black tank.
9. Pour anti-freeze down each shower/tub, lavatory sink, and kitchen sink to fill p-traps.
10. To winterize gray tank(s) pour one gallon down each related sink drain.
*****Now the best thing is to post a new post and see if someone has your manual to be exact.
But if you get no response, and refuse to let a dealer do it, you have a little bit of info to help you.
Sorry I couldn't find the exact method for your model.
My BMW 318 ti, 1998, overheated, I completely replace the thermostat, I change the radiator temperature sensor, I replace the plastic parts of the radiator, but rolling the car consumes anti freeze, I...
If the car uses anti-freeze without leaking, it is going out the tailpipe. You either have a bad head gasket or a crack in the head or block.
1helpful
1998 gmc yukon 4 wheel drive what does it mean when the number5 cylinder is misfiring and I changed the plug and the wire,just had a full tune up with coil and module,fuel filter! What could be the problem...
cHECK YOUR ANTI-FREEZE LEVELS IT IS PROBABLY LOW. These engine are famous for the in take manifold leaking internally and externally on cylinder # 3 & #5. This will cause the computer to give a misfire code. Tzop up your anti freeze and pressure test the cooling system I can gauruntee you lose pressure and it will be your intake gasket. You will have to replace it the gasket kit cost about $100.00 make sure you but the Fel Pro gasket kit it has been redevelope and made from steel rather than plastic. This will solve your problem and your truck will run much better as well.
Engine warms well, heater fan blowing well, but very little heat comes into cab
It could be one of two things.
1. Bad thermostat. Your thermostat is pobably not opening when the engine warms up. Install a new thermostat and you should be OUT OF THE COLD. If not,
2. Your heating core and radiator is probably clogged. One way to solve this is. Flush out your radiator with radiator flush kit. Pease read your owners manual, (YOU NEED TO USE A SPECIAL TYPE OF ANTI FREEZE). If you use the the green color Presotne anti freeze, It will gradually corrode through the linings of your radiator. And the green color prestone anti freeze will blow out the radiator. So read your owners malual ( I beleive it says you have to use Dextron Anti Freeze ( Pink Color).. Replace your thermostat and flush out your radiator. Then refill your radiator with dextron anti freeze. Also make sure the anti freeze resivor is filled to the proper level.. Once you do all of this, YOU DEFFINITLY WILL BE IN HEAT.. YOU CAN DO THIS YOUR SELF ( iT WOULD TAKE ME NO MORE THAN 1 TO 2 HOURSFOR ME TO DO THIS IN MY DRIVEWAY) OR YOU CAN HAVE THIS DONE AT ANY QUICK LUBE LOCATIONS... HAPPY MOTORING
Coolant temperture location on a 1994 ls 400 lexus no start when cold
coolant temp will not cause your car not to start the coolant resivor is on the right front side of your engine dont over fill it it has a mark on side of it for max and min levels use 50/50 anti freeze parts store sells it they also sell test kits to test the strenght of the anti freeze in your radiator good luck
Have a 2002 ford explorer with 4.6 engine going through anti freeze 2 gallon a week. anti freeze in oil took heads off and did not see any bad gaskits or any signs of warpage on heads not sure if just the...
Hi ...i suggest changing your head gaskets ...it will come in a complete kit ....do it all ....just looking at a gasket ..some times it hard to tell .....once you take the heads off always change the gaskets ...never will properly seal again ....
GE Model TFX20JRBAWW auger freezes up and no ice will dispense ice is accumulating at base of auger. the bottom of the bucket is solid ice every day.
there is a anti-freeze kit available. u will have to completely dry the motor first. (if you hold it long enough the heat will build up in the motor and thaw itself)but will freeze right back.
Top Refrigerators Experts
vince
Johnny 1000
