Question about Behringer C-1 Microphone
How to i test to see if a mic element is still working
  • 63 Answers
The easiest way is to plug it into a mixing desk or microphone input on a sound card. However, whichever you do you will need phantom power as this microphone requires it.
Posted on Aug 28, 2012
6ya staff
SOURCE:
Hi there what color are the mike wires trans,recive,audio, and screen
The colors shouldn't matter.... check the mic switch. and follow your wires to the mic plug. the common wire is normlly the ground to allow RX then when pressed for TX the other should then be your audio which will be connected to the mic element.. using this method you can wire any mic to any radio.. pending the mic element ohm value impedance is correct for the radio.
Dec 31, 2015 | Radio Communications
Wiring code super star mic to rca copilot 14T 303
Dec 06, 2015 | Radio Communications
How to get some bass out of it
Generally, that is due to a cheap mic element. The only way to really fix it is to replace the element or the entire mic with one with a wider frequency response range. There are lots or replacement mics available.
Oct 01, 2014 | Radio Communications
Cc-40 headset microphone will not work
The mic element has probably gone bad. You can verify this with a multimeter, measuring between pins 1 and 2 you should see either infinity or 50-400 ohms depending on the element. If you get open circuit that is confirmation the mic element is bad.
Feb 13, 2014 | Clear-Com Radio Communications
My webcam works fine on other websites but when i try to talk nothing happens. It works fine when i test it but not on websites
You need to set the mic you wish to use with the webcam as the 'Default' mic
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Aug 25, 2010 | Logitech QuickCam Fusion Webcam
I hav a microphone problem.Its working properly on my pc,but when when i connect it to my social netwoking site it doesnt work properly,some wired noice comes out th speaker of th one who is listning to my...
Go on mic. configuration and select on microphone use from configuration mic. name and test the mic. On test mic not works mic,is posible to need a driver for mic and need download and install the driver.
Jul 30, 2010 | Computers & Internet
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
Sound won't work
make sure the webcam mic is set as default - especially importsnt if you have laptop with a built in mic as well
TEST SPEAKERS
Restart computer
May 02, 2010 | Logitech QuickCam Communicate STX Personal...
During performances the mic signal cuts out and comes back in. What are some causes of that problem?
If it is wireless mic, then either low battery, interference from other devices, or damaged element in the mic.
If it is wired, then damaged element or more likely a bad cable is at fault.
Also if you are using a noise gate and the threshold is set too high would do it.
You don't mention what type mic. I will say that most mics do NOT bounce very well and elements are often broken.
Sep 29, 2009 | Shure Audio Players & Recorders
Dropped the mic.
I would imagine the mic element broke. To test, remove from the case and without touching anything else, touch (using a small screwdriver if need be) the solder connections on the wires for the mic element (while system is up). Hum? Yes? bad mic element. No? Problem with electronics. Look for broken wires also.
The receiver shows signal so RF is ok. You have a problem with the audio section.
Apr 28, 2009 | Audio Players & Recorders
Behringer C-1 Microphone Logo
100 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Rob Beech
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
