WILL NOT CUT PROPERLY ,NEW CHAIN FITTED & OIL WORKING BUT SEEMS TO BURN INSTEAD OF CUT
I do not mean this as an insult but since I have seen it before I have to ask if you put the chain on backwards?
Other then that I know that if you hit dirt, even with a new chain, it will dull it quicker then anything else.
Testimonial: "Simplest thing chain on wrong way thankyou for your imput much appreciated Regards Fred"
SOURCE: The chain has come off my bosch ake 40-19e
first loosen the bolts that hold the bar in place. then find then loosen the adjustment screw. Once it is loose, the chain will go back on the bar. Then tighten the chain so there is only about 1/8" movement. (You will want to tighten the bolt so they are snug, when you are tighting the chain) Once that is complete re-tighten the bolts completely.
SOURCE: I need a chain for my ake 40-19 S chain saw. What
I tried a Google search for "Bosch ake 40-19 S chain" and found many on-line outlets. If you take your chain (they need it to use as a pattern) to a local saw shop or a good hardware they can probably fabricate one in a few minutes and you will save the shipping and handling costs.
Chain installation (bottom) may be helpful:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: my bosch ake 35s isn't cutting, what's wrong with
Chain has dulled. Needs sharpening.
Hitting one little imbedded rock in the wood and the chain can be dulled to the point it only burns the wood.
Replace the chain or have it sharpened.
