Quintrix tVs are very very old model. I'm not sure whether it can be synchronized with codes for mode tVs. Anyway, try these Panasonic Codes: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070 If you do fail to do, please don't blame me.
Three digit codes for Panasonic are: 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
SOURCE: need tv code list for urc-4605
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4605
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
SOURCE: Total control urc-2082 universal remote control
Here are all i have
0579,0060,0261,0035,0744,0577,0214,0066,0110,0216,0446,0366,0593,
0397,0023,0795,0032,0223
SOURCE: one for all remote urc 7940
i entered the codes from the book but none of them worked for my AWA tv. the remote works on other tvs
SOURCE: total control codes urc 11-2082
codes daewooTV are: 0657 0397 1932 0522 0060 0579 0032 0239 0241 0684 0240 0474 0062 1160 1925 1951 1931
Try these, I can't gaurentee these will work...but hopefully you have some luck with it.
Universal remote code for all Technomate models
Quote:
All TM-1000 Series 249
All TM5000 Non super Series 251
All TM-5000 Super series 253
All TM-6000 Series 606
Some universal remotes need 4 digits
Add 0 before above numbers
Example 0249
