Unable to turn TV via power button or remote. Nothing happens, no lights, no sound nothing. Its like the power is not getting to it. I've tried a different cord, and have taken it apart and do not see any bad capacitors. Anyway know a way to figure out what part went bad?
The power supply regulator section is not working properly. It will be best to replace this board as card basis rather than trying to make it right. Philips have used some special numbered components there, which are very difficult to get from open electronic spare part market. Contact the nearest authorized service center for Philips to buy a new board.
SOURCE: Blinking red light, doesn't turn on Philips 32".
count the blinks from the red led this number will tell you the stage of the poss fault
SOURCE: I can't get my tv to turn on... nothing but blinking red light
Thats nots it its bad caps.....
need to replace 3300uf 10V with 3300uf 16v or higher. A couple of bucks in parts and some soldering.
Fixed both of my 50" sets
SOURCE: replacement of fuses on Philips 37PF7320A 37 in. HDTV-Ready LCD
5 amp and 1 amp - slow burn fuses -- they have them at radio shack under 3 dollars for a set of three
SOURCE: Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
SOURCE: philips-plasma-tv-wont-turn-on-all-i-get-is-a-clic...
OK this is a classic switchmode power supply problem There is a fault either IN the SMPSU, OR in another part of the set, usually a short circuit. The PS, is "Shutting Down" for safety reasons, so as to avoid a possible fire, explosion etc. You really need to have this looked at by a qualified person. before you get any work done, always ensure you get a firm "Quote" before proceeding. This is very common.
