On the wash cycle it doesn't agitate both ways, just turns one way
SOURCE: hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
SOURCE: need to remove agitator on
thank you for your prompt responce i did ring a local repair shop who was very helpfull and explained how to remove the agitator and put it back in . again thank you
SOURCE: hoover 800 washing machine
take the cap of the top of the agitator you need a 10mm socket
on along extension bar undo the bolt in the bottom of the agitator and it will lift out replace by do-ing the reverse process
i have just done it better than paying $100.00 for a service call
for five minutes work
SOURCE: the 7kg hoover will wash then stop agitating
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
SOURCE: Hi, My Hoover 600MB top loading
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
