Insignia NSDSC10A Digital Camera Logo
Posted on Aug 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have connected to camera and computer with camera saying it is connected, but when I click on add pictures from camera, my computer is saying it is not properly connected.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Insignia Master 102,366 Answers
  • Posted on Aug 24, 2012
Insignia Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10434476
Points
622693
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
How to add a photo from your camera to a gmail you are sending???
connect your camera to the computer and upload and save it to your desktop. Go to your gmail and click the paperclip that says add picture, Through that go to desktop and click on that photo u want and it should take only a few seconds to load.
I have a Kodak EasyShare C195 Digital Camera. I have pictures stored on the camera (on the removable card) I want to view those pictures on my computer. I downlodaed the EasyShare Software from the...
Try using Windows instead of Kodak. With your camera plugged in and on open my computer and see if your camera is listed. If it is you can click on it press control and a to select all of the pictures, control and c to copy them, then open my pictures and press.control and v to paste them. If you don't see your camera listed open control panel, devices, scanners and cameras, add/find camera, follow the prompts to add your camera.
Computer does not respond to camera being on and plug in
  • Start EASYSHARE Software.
  • From the menu bar, select Help > About Kodak EasyShare software.
  • Note the software version. If you have Version 8.0 or later installed on your computer, review the help information for Transfer Pictures.
  • From the menu bar, select Help > Kodak EasyShare Help.When the Welcome to EasyShare Software window appears, select Transfer pictures, then read the help information.
  • If you do not have Version 8.0 or later installed on your computer, go to EASYSHARE Software Downloads, then follow the instructions to download the latest version of software. Approximate download time is 5 minutes for Cable/DSL, or 2 hours for a dial-up connection.
If that doesn't solve your problem you can manually add your pictures/videos to easyshare software.
  • In easyshare Software, select My Collection, then select Add Pictures. The Add Pictures screen appears.Look at the Select a location field. If the My Files folder is collapsed, click the + to open the folder.In the Select a location field, select your camera folder, for example: M381 Digital Camera. Thumbnails of the pictures/videos on your camera internal memory, and on a memory card if one is in your camera, appear.
  • Select the pictures/videos to add to EASY SHARE Software, then click Add Pictures. To add all the pictures/videos in the folder, click Add Entire Folder.Click Done.
Thank you !!
Pc wont recognize camera. windows xp
Thank you
My computer won't recognize my camera. All of the USB ports are working (I checked them with other devices) but none of them are working for the camera...
Thank you
5helpful
Transfer problem with kodak MD1063
With the cam connected , open the easyshare software ,bypass the transfer window then click on the ADD PICTURES icon on the top left,under SELECT A LOCATION click on the model no. of the cam. Tag all the pictures you would like to add, then click on ADD PICTURES. Click on DONE once finished.
2helpful
2answers
Downloader says no pictures on the camera!
Computer does not recognize camera and unable to download pix???? It sounds like a bad usb cable connection. Try purchasing a new cable.
67helpful
7answers
Trouble uploading "duplicate" pictures
I've just found a fix for this problem after fighting it myself for a week. Don't use the transfer window that Easyshare gives you when you connect your camera (or which is also available under the tools/cameras/viewers dropdown menu).
Cancel this window if it comes up. Then select "add pictures" from the file dropdown menu (as if you were going to add pictures from your hard-drive to the easyshare gallery). The camera will appear in the folder list. Open the m1063 folder, select the pictures you want (or select all) then click the "add pictures" button.
-Neil
1helpful
2answers
Hannah Montana Camera, says there are no pictures on camera to download
Depending on your operating system the downloader program may not work.
1. Open 'My Computer' or 'Computer' on Vista and connect the camera to the PC.
2. Watch the screen for a new "Removable Disk" to appear.
3. Double click on the "Removable Disk".
4. Double click on the folder "DCIM".
5. Pictures will be located in the listed sub-folder. This should be named "100IMAGE".
You can then drag and drop or cut and paste them into the My Snapshots folder located in My Pictures.
Cant download pictures
- install the software
- restart computer
- connect camera to PC, but make sure camera is turned off
- after connecting the camera, and the computer is ready, turn on the camera
- select Computer on camera LCD
- go to My Computer
- click on Removable disk
- click on DCIM
- click on 100SSCAM
- select all the images and copy them
- select a folder where the images will be saved
- paste the images
Top Insignia Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Insignia Camera Expert? Answer questions, earn points and help others
