Usually there are two reason for this: - your felxible cable that connect the main board and the touch screen is defected and must be changed - your touch screen is defected
Well, for starters, the camera can be defected, because you said that when you charged the battery, it said it was on low, correct? So you should probably send it to the manufacturer, Sanyo, and they might give you a new Sanyo camera, since you got it defected. BUT first, you should call, and ask for more reference. Secondly, just see cheap deals on eBay, & Amazon, so buy a new battery. If you find that you DID charge it, than the Camera itself is defected. But their is also a chance that your area you charged it in IS either too hot or too cold, causing the battery pack to take longer, and lose the battery itself. Hope this info. helps!
open your phone and find is the contact that connect the board with the ******** is defected or and any dust on that,. and also ensure is your phones vbrator is working or its defected
the problem of the continuos blowing of fuse internally is as a result of a defected component on the pcb board of the recevier .
you can do this by removing the cover of the recevier and check for the power transistor , power capacitor, if is defected with the use of a multimeter, replace for a new one of the same number
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Sound like high voltage splitter ( born or defected ) Am sure this is your problem. Or maybe fly back defected. Check for possible loose connections. Thank you !!
Sometimes the electronic device thats programed to open the door malfunctions from wear and tear or its just defected from the manufacture, if you have warranty send it to Gemsound so they can replace the defected peace.
