Samsung HP-R5072 50 in. Plasma HDTV Logo
Lindsay Davner Posted on Apr 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
50 Inch Samsung tv
I have a 50" Samsung HLP5063WX/XXA tv and it made a loud poppin oise and powered off and when you power it back on there is no picutre.
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Apr 04, 2007
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336461
Points
2402
The tv is having a high voltage problem.what happen it was a short that cause you tv to stop working contact a tech to look at it.good luck.
2helpful
2answers
Screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
1helpful
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
1helpful
I have a Samsung DLP 50 inch tv, model #HLP5063wx xaa. A friend gave me the tv, and told me it wasn't working, probably needed a new lamp. When I try to power on the tv, it comes on but makes a terrible...
the lamp led will light when the color wheel is defective. If the noise you hear is a buzzing or screeching the color wheel is the most likely cause.
2answers
Samsung 50 inch plasma... no power to tv
ours is doing the same thing first time they said a circuit was loose. Repair man due back out Tuesday
2answers
Samsung HLP5063WX -- 50 inch DLP
I have the same problem. I called Samsung and talked to a tech who thinks it could be the barrings in the "color wheel" are going out and making the noise. He didn't think it was the fan because that doesn't turn on until the tv warms up. After a 30 minute discussion he felt certain that was my problem. I haven't had it repaired yet so I can't be sure. Hope this helps.
P.S. I don't have any problems with the color.
1helpful
2answers
Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
1helpful
I have found the most common problems with the symptom you have described, to be the SMPS PCB. Sometimes the Y Main will cause the power supply to short out and lower a voltage in that area. Your set has a two year warranty. Call 1-800-Samsung to find an authorized servicer in your area.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
