I have a Coby TFDVD 2284 want to get off cable & use the free tv stations. How do I do this ... Coby Flat Panel... ' Answered ... 22 inch coby flatscreen won't start.
Feb 27, 2014 - I have a Coby TFDVD 2284 want to get off cable & use the free tvstations. How do I do this ... Nov 24, 2014 ' Coby Flat Panel Televisions.
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
It sounds that the main board to this TV is damaged. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts.
I'm not certain but it sounds like there is a loose video cable in there...if you are able to, take the tv apart, and literally push on all of the connectors and cables to make sure they are not loose. The main video cable may not seem to be loose, but once it is making contact again, it should clear that mess up. Just look for cables running to the main screen and pull them off and put them back. Then put the tv back together again and see if it worked...it usually does. why does this happen? Some blame it on dust, others blame it on quick manufacturing processes...whatever the case, the cables become slightly seperated from the controller board and that happens...it also happens to computer monitors too...Good luck and take your time. If there are a lot of screws and things either take pictures of where they all went or write it down. I like to make a diagram on a piece of paper and tape the screws on the diagram to show where they went.
Howdy, If you want good sound from a Coby TV you need external speakers. Coby is one of the lowest end producers of televisions and are notorious for poor sound. Good news is that for what you saved by buying a coby, you are still ahead after buying external speakers and amp (often called home theater system, some have built in DVD player). That's the scoop on Coby. hope this helps some.
Regards, Farmerbear
