Gateway MP8708 Notebook Logo
Anonymous Posted on Nov 22, 2017
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
After Windows Update Laptop wont boot into Windows, No F8, No CD Boot, No USB Boot - BIOS is fine, reset battery, HD, memory F10 give you selection but no boot. Press power button once and it turns off. Already tried re-seating memory too. Can't figure this out! No beeps no warnings no errors in log file.. What gives?
GI Consulting
Level 2:
Scholar:
New Friend:
  • Expert 119 Answers
  • Posted on Dec 20, 2017
GI Consulting
Expert
Level 2:
Scholar:
New Friend:
Answers
119
Questions
0
Helped
25565
Points
405
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Mar 08, 2008
SOURCE: Notebook will not boot
You need to get a windows install disk
Anonymous
  • 49 Answers
  • Posted on Oct 11, 2008
SOURCE: My windows xp cant boot propery it is restarting itself.
-Try to boot the system to windows xp cd,then run windows repair.
-repairing windows make take up to 1-2 hours depending what capacity of hdd you have but you may need to complete the repair.If repair failed to complete.
-contact manufacturer and have them diagnose the entire system. and chck for the system warranty and look if there any error code if the error code lead to replacing the hdd, then request to replace the hdd.
Anonymous
  • Posted on May 04, 2009
SOURCE: Gateway MX6927 Windows Xp won't boot
put your xp disk in the optical drive.Turn off computer. Turn computer back on as soon as you turn it on start tapping f 12 constantly.it should go the boot menu giving you a choice of booting from cd or hard drive choose boot from cd.Be sure you choose repair rather than new installation or you could loose all your information stored on the hard drive,I personally would try safe mode first you can get to safe mode by tapping f 6 when you first turn on your computer.
Anonymous
  • Posted on May 01, 2010
SOURCE: gateway m-6843 won't boot
I am having the same problem. Elix, that is a great suggestion, however this particular model from Gateway does not ship with a recovery CD. There is a recovery partition on the HDD, however with this particular problem the recovery partition is not accessible.
Anonymous
  • 32281 Answers
  • Posted on May 21, 2012
SOURCE: Gateway mp8708 s/n t23691006485 showing disk error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
4answers
G31-M7 TE keyboard problems
you have to run the DRIVERS CD FIRST.
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Keyboard not wirelessly connecting
Sounds like the battery in the keyboard is dead. Also make sure you have the wireless doggle that came with the keyboard and mouse plugged into the usb port. You might try plugging it into another port.
I'm thinking your keyboard is dead because of the battery or a virus has hijacked your keyboard.
Try booting up in Safe Mode to make sure it's not virus related. Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option and let it boot up. Safe Mode will look different because the icons are bigger and the screen is darker, this is normal. If your keyboard works in safe mode then you might have a virus that can't function in safe mode.
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
2answers
How do I turn on the numlock on my HP ProBook 4525s? I press the numlock key with no results.
from bios, /setup/ , there will be Num lock - disable, change yo enable, or read it,
http://www.pdspc.com/digitalcontent/USER_MANUAL/1b912539-e1cd-412d-ad8a-758270f5458e.pdf
2answers
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
