I want to load IOS in flash drive , but i cant assign ip address for the router .. how can i configure
With the set command.
Example:
rommon > set
PS1=rommon ! >
IP_ADDRESS=172.18.16.76
IP_SUBNET_MASK=255.255.255.192 DEFAULT_GATEWAY=172.18.16.65
TFTP_SERVER=172.18.16.2
TFTP_FILE=c2600-i-mz.bin
Alternatively you can XMODEM an image on there. However, that takes a long time, even if you increase your baud rate.
Also, on 2800 series routers you can put the image on a USB flash drive. However, the drive must be formatted as FAT and the partition size cannot be larger than 256 MB. This might work for an 1841.
SOURCE: cisco router 1841 connected to serial interface
Theres no need to setup for the nat but please check the wan interface and subnet mask ip it has to something else and not 255.255.255.252..Try 255.255.255.240 it must work...
SOURCE: Problem in IOS loading in 1841 router
Hi managobinda,
Try booting from a usb flash:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon_ps5853_TSD_Products_Configuration_Guide_Chapter.html#wp1064046
** make sure that the image that you are loading is not corrupted
If still no good, try xmodem:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon_ps5853_TSD_Products_Configuration_Guide_Chapter.html#wp1044991
Hope this helps.
Regards,
ex_ocsic-cat
SOURCE: No ip assignment with cisco 5400,radius server and isdn config
Sounds like you are missing AAA author for your PPP sessions. Without seeing your config, it is a bit hard to give you more help.
SOURCE: VPN (ipsec)
the full instructions are here:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_example09186a008073e078.shtml
SOURCE: 1841 router in rommon mode cannot install flash
Basically you will need to use TFTP to get the IOS back on. HERE is an article from Cisco that explains how to do it. I have done this before and even though it takes a while to reload the IOS (because in my case I had to use a serial connection at 9600 baud) it does work.
