I deleted my ios in my flash drive . it went to rommon mode ... hw can i reload the router into flash. I cant assign IP address for router
Basically you will need to use TFTP to get the IOS back on. HERE is an article from Cisco that explains how to do it. I have done this before and even though it takes a while to reload the IOS (because in my case I had to use a serial connection at 9600 baud) it does work.
SOURCE: cisco router 1841 connected to serial interface
Theres no need to setup for the nat but please check the wan interface and subnet mask ip it has to something else and not 255.255.255.252..Try 255.255.255.240 it must work...
SOURCE: Problem in IOS loading in 1841 router
Hi managobinda,
Try booting from a usb flash:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon_ps5853_TSD_Products_Configuration_Guide_Chapter.html#wp1064046
** make sure that the image that you are loading is not corrupted
If still no good, try xmodem:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon_ps5853_TSD_Products_Configuration_Guide_Chapter.html#wp1044991
Hope this helps.
Regards,
ex_ocsic-cat
SOURCE: Router not responding to http request
possible firewall on the router check settings make sure its not blocking ping requests everything else works?
SOURCE: change IP address of Cisco 1841
once in enable mode, goto config mode. then select interface, i.e. f0/0 and then type in the following:
ip address x.x.x.x y.y.y.y where x is your IP address you wish to have and y is the subnet mask
example below:
router#config t
router(config)#int f0/0
router(config-if)ip address 10.0.0.1 255.255.255.0
hope this helps!
SOURCE: I have cisco 1841 router stuck at Rommon> only
what shows the following?
dir flash:
If IOS is ok the follow the below step
The router will guide you through changing the registry. You want to press y to chang the configuration. The only other change you need to make is the change to the console baud rate, set that to 7 (115200).
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
enable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
disable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]: y
enter rate: 0 = 9600, 1 = 4800, 2 = 1200, 3 = 2400
4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200 [0]: 7
change the boot characteristics? y/n [n]:
Configuration Summary
enabled are:
console baud: 115200
boot: the ROM Monitor
You must reset or power cycle for new config to take effect.
rommon 2>
3. When you reset the router in your console window you will see characters that you cannot read. You have to stop the session and set your baud rate to 115200. This will let you increase the speed that you use to transfer the file.
4. At the rommon prompt enter xmodem -c {filename}
5. When prompted, enter y to continue
6. From your hyperterminal prompt, click on transfter then send file
7. Select the IOS image then change the protocol to xmodem via the dropdown box then click send.
8. After the IOS has been downloaded, change the boot order by using the confreg 0x2102 command.
Please check the below point and revert if any queries
