Ricoh Aficio GX E3300N InkJet Printer Logo
Posted on Aug 25, 2012
Ricoh gx3300n Blinks lights on start but fails to power
Changed cables .all we get is a blink once .it wont blink lights on pressing stsrt button again ..switch on and off at wall you get another blink.
davej42
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 15, 2012
davej42
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
366
Points
Your printer is fried but i bet you figured that out by now. You using Saw grass ink i bet. Well thanks to them you now have boat anchor. The ink destroys the printer. I got one 2.
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
2answers
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Mac g5 wont start led light blinks once every 7 sec
Hold down the power button until the computer shuts off. The press the button to restart and see what happens. There are several different ways to startup. immediately upon hearing the boot tone, press and hold the shift key to boot in safemode. If this fails as well, then you will need to boot with the install CD. This is done by immediately pressing holding the C key upon powerup
I need codes for a motarola cable
i dont see the code for the name but it does say press the code search button till it stays red press number one at a time 0-9 if the light blinks once that would be your first digit if it blinks several times its not then repeat process for the 2nd and 3rd digit code once u found the 3rd the light will go off then u have thirty seconds to press cable button
Acer aspire T120c wont start red light blinks once when i push the power button
If you turn on the computer and it will beep once and the red light blinks means the computer is starting will.. but if the computer beep once and the red light blinks once means there are something missing or something bothering the computer.. try this Check the connection cable of your computer, the power source, the hardware interface, and if you installed a new hardware, try taking that hardware out and turn on again the computer. if the problem still exist try to disassemble and assemble the hardware of the computer. You must have someone with you know how to assemble and disassemble the computer hardware for safety method TY.
HOPE I CAN HELP
1helpful
Kidz Remote
RE: Programming a Kidz Remote by Kissel By helpmedave (Guest Post) 1x1.gifthe procedure to program the remote is as follows.
Find the setup button recessed between tv and cable buttons. Use a toothpick to press the setup button until the led blinks once, keep holding it until it blinks twice then release. press tv or cable button then enter the 3 digit code for the device you want to try. the light will blink twice if the code is valid. ( yeah i know you don't have the codes ) (me neither ) if you successsfully program it to control a device, you can then program each button as follows. hold setup button until light blinks twice.press tv or cable as needed. press 995 the led will blink twice . press the button to program. enter channel number you want (may have to enter 2 or 3 digits 08 008 etc)press setup light will blink once.m select another button and repeat to program all buttons you wish to program.to lock in settings, press setup until led blinks twice. good luck.Posted on 08/09/2007
27helpful
9answers
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
3answers
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
