There is a special tool required as the screw heads are splined, base settings are 1 1/2 turns on both, it should run at this, the L screw will adjust fuel flow from idle to half throttle, the H screw will control the fuel to full rpm.
If the engine struggles to pick up, unscrew L screw a further 1/4 turn, or more until it picks up cleanly.
Now at full revs, gently screw the H screw in until engine sounds sweet, if it starts to die unscrew to achieve full revs.
How long has the gas been in the Blower?
If it was 10% Ethanol gas( lie most States sell at the gas pump) and it has been in the Blower for more than a few months, you probably have carburetor issues.
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
The ratio is 50:1. Use a good quality 2 cycle oil for mowers and equipment, not for boat motors. You can probably buy a bottle for the 50:1 ratio with just the right amount of oil. Look for a bottle with 2.6 oz. That is the correct one. You can use either regular oil or synthetic oil.
If you need an owners manual, go to Husqvarna.com and look for the homeowners manuals. Search for yours with a space between the 130 and BT( 130 BT )
