What does picture control do
SOURCE: PT-51HX42 51inc. - picture bowing
This happened a few years ago to me. I called the repairman out and he said that I had my tv too close to a magnet source, which turned out to be a speaker and also the reciever for my home theater. See if this may be your problem. Good Luck.
SOURCE: cannot adjust blue convergence on panasonic
If you cannot adjust it then it is broken.
You can find websites online to change out the convergence amps, or you can pay a pro to do it, usually about $300
SOURCE: I have a panasonic pt-51hx42. I was just
your convergence power supply blew a fuse & probably one if not both of the STK ics. Normally when this happens the short takes out the low value resistors connected to the ics.
it is common practice in the shop to replace both STKs and resistors
SOURCE: Panasonic 56
You have a defective temperature sensor
3 blinks flashes oncenevery 5 seconds
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
Please rate my help++++Thanks for using FIXYA
SOURCE: 51"panasonic pt-51hx42....colors are seperating..lower picture
This kind of distorted picture comes when tv got problem in convergence output section and mostly convergence output chips got bad that need to be replaced to solve the issue.
Chips replacement requires soldering work in tv circuit board and local tv repairman will do this job fr you if you have no prior experience.
Let me know if you have additional question.
Thanks.
