Question about Panasonic Lumix DMC-FZ28 Digital Camera
FZ28, backlit ribbon cable broken
Backlit flat ribbon was cracked at the 90 degree bent which gets inserted on the PCB, is cable available?, or any other method?. Right now my LCD is blank but I am able to operate camera via eye piece
6ya staff
SOURCE:
Anonymous
  • 188 Answers
SOURCE: Panasonic Digital Video Camera NV-GS35
the flexible ribbion cable carring information from the camera to the LCD monitor gets damaged in time. You have to get the cable change.
Posted on Jul 22, 2008
jimikid2002
  • 3 Answers
SOURCE: FZ-30 LCD flat ribbon cable broken
Part No is VYQ3473. You can order it directly from Panasonic. It will cost you 29 USD without taxes.
Jimi
Posted on Jan 26, 2009
Anonymous
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
Posted on Jul 05, 2009
riceski
Gary Rice
  • 1851 Answers
SOURCE: Have been refused repair of my Panasonic FZ28
What are the details? I need much more information If purchased new - when - model - all s/n numbers and a copy of the receipt and guarantee will be needed. The store purchased etc. I will need to speak with you via Email - Email me at riceski@gmail.com and we can talk particulars. I am good with getting companies to honor these sorts of things so give me a try.
Gary
Posted on Feb 03, 2010
Ty Price
  • 11967 Answers
SOURCE: Camera FZ30, My ribbon cable
How did the ribbon cable get broken? Why don't you want a replacement from the manufacturer? How much do you really think you're going to save? Do you know how to replace the cable?
Posted on Nov 01, 2010
Can we change normal laptop keyboard to backlit keyboard? For lenovo G50 70?
I don't think so that the laptop supports backlit keyboard as there is no cable for keyboard lights in motherboard but i suggest to check with lenovo suport first.
Jul 12, 2018 | Lenovo Computers & Internet
The tv does 't respond to the remote control
Keep your mobile camera on. Remote sensor face to camera and press any switch from remote. If you get light from remote sensor in camera that mins remote is ok but problem with LED remote sensor PCB
Jan 27, 2016 | Sharp LC46LE830U - LC 46LE830U - 46 Aquos...
I'm totally confused, can be someone has other ideas what should I do to enable keyboard backlit
despite a port on the motherboard for the back-lite option, not all motherboards actually have all the supporting hardware. Those that do, but aren't equipped originally with the backlit keyboard typically haven't installed the basic drivers to operate one.
start by opening: [control panel]>[system]>[device manager] and select 'search for new hardware'
Oct 31, 2014 | Lifetime ASUS N71Vn Replacement Laptop...
Phone not backlit
The Mitel 4025 (and 4125) was originally available in two models, an earlier non-backlit model and a later/newer backlit model. There is no lighting available in the non-backlit model, so if that's what you have, you're out of luck.
Feb 04, 2014 | Mitel Superset 4025 Corded Phone...
I am having trouble reconnecting the 4 connector FFC for my backlit keyboard.
Check the connection on the motherboard a little closer. There should be an unlockable part in the connector which you can slide back and forth in order to remove/fix the cable.
Jan 13, 2013 | Computers & Internet
HOW DO YOU TURN LIGHT BENEATH KEYBOARD ON TOSHIBA A660/07T
I'm not sure what model you have I do not see a A660/07T.
Here is a listing of the different models that have an LED Backlit keyboard. http://us.toshiba.com/computers/laptops/satellite/A660/available-models?EXTRAS=LED+Backlit+Keyboard&SERIES=A660&SUBBRAND=Satellite%26reg%3B&Ns=pUnitsSold'1&sms_ss=email&at_xt=4cddcae4e07d677f,0
Mar 05, 2011 | Toshiba Satellite A100-S8111TD Notebook
Panasonic DMC FX8 LCD screen fault
I have the same problem. I opened the camera and its the way it was assembled, the 4 wire flat ribbon cable that connects to the backlite screen not the actual LCD screen is broken where it was folded 90 degree and taped down. It must of got dry and just cracked right on the bend. So we need a new backlite screen not the LCD. Where do we get it? Does it come with the LCD???
Jan 20, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Broken flat ribbon cable on SD 28 flash
Hello, after breaking mine this morning I was able to fix the flash so It can fire from the hotshoe.
Any automatic TTL features will still not work however atleast you will be able too fire in auto, and manual modes.
I simply opened the flash by taking off the hotshoe, and then swiveling the flash head 90 degrees to expose the four screws there. You need only remove the two screws from the front side of the unit.
Open the battery door and gently pull away the front case (Be careful there are several delicate ribbon cables that you do not want to snap. From here you can either unscrew all the ribon cables to free yourself room to solder or try and dodge them.
You should now be able to see the rear side of the PC sync socket. There is a blue wire that joins the outer edge of the socket - this is ground. Solder onto this point and join onto the top left circle of the PCB board of the hotshoe. (Opposite corner from where the ribbon cable attatches) There are copper circles exposed on the pcb for easy soldering.
Next, return to the rear of the PC sync socket and note the orange wire coming from the centre pin. Solder a wire to this point, and then down to the hotshoe PCB and to the circle that joins to the centre pin of the hotshoe. (Trace the circuit paths)
Sorry I did this about 30mins ago and I'm remembering this out of my head.
Goodluck
Jan 07, 2008 | Nikon SB-28DX TTL Flash
No backlit
Long shot---try to take the battery out and then reboot after you put it back in. On the backlight prob...I smell smoke.
Aug 27, 2007 | Motorola Mobility E815
CASIO E-125 no backlit
Usually the ribbon cable connection that powers the backlight is the problem.If you remove the four screws in the back and take off the back cover. (note that there are two tabs on both sides of the cover half way up)You can see the white ribbon cable on the left above the battery back housing. Gently wiggle it and see if the backlight goes on. The cable is attached with a small brown insert that holds it in. It is removable so you might be able to get an electronics shop to replace the cable connection or the cable itself.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Panasonic Lumix DMC-FZ28 Digital Camera Logo
37 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
