Will not run unless choke is full on
SOURCE: 8hp briggs and stratton in a go cart. is feeling
Make sure the governor baffle is working freely. and the carb has no crud in it. Chk out this site:
bsppwebtools.com/data/manuals/1678_0esfw.pdf
SOURCE: I have an 8hp briggs on a coleman generator and it
Drain the gas out of it. If there is a fuel filter, replace it. Get some carburetor cleaner and put a little of that plus a little fresh gas in the tank and run it through. Do that a couple of times until it will run without the choke. If that doesn't work you will have to disassemble the carb to clean it. Use a gas additive like Sea Foam to keep the gas usable longer without gumming up. If you are going to leave it unused for a month or more, run the gas out of it.
