Need diagram to put belt on 5 pulley motor
Start from bottom crankshaft pulley and ac compressor turn belt tensioner counterclockwise or lift forward then run pulley belt around crankshaft pulley and around AC compressor,run pulley belt around power steering pump then around alternator,once drive belt around alternator you done make sure drive is center of crankshaft pulley and AC compressor pulley.and belt back is center against water pump pulley before releasing the belt tensioner.
SOURCE: 2001 pontiac sunfire serpentine belt diagram
go to autozone.com and it will give you the belt diagram
SOURCE: 1999 pontiac bonneville ssei supercharged belt routing diagram
This is the one for the supercharger.
SOURCE: serpentine belt diagram?
Should be a diagram sticker in the engine compartment, either under the hood or around the top of the radiator.
SOURCE: 2006 Nissan frontier 4 cylinder belt diagram + tensioner pulley
They are under the hood or on the front crossmember.
Regards,
matt
SOURCE: Serpentine belt diagram for a 2001 Pontiac Bonneville SSEI
these motors have two carrier pulleys and oone tensioner. lookinjg at the motor from the rightside of car the belt goes as follaws: crank pully to super charger from the left. the right side goes up to the lower carrier which will have the flat of the belt riding on it. from there the belt routes to the upper carrier
[ loop it over so the grooves ride
] and then under the tensioner any questions contact [email protected]
Park the Pontiac in a safe work area and open the hood.
Inspect the top of the black plastic cover that surrounds the fan for the serpentine belt routing diagram. This diagram has the instructions for installing the new serpentine belt around the accessory pulleys.
Inspect the front of the engine and locate the automatic belt tensioner. The tensioner on the 1999 Pontiac model vehicles is located between the alternator and the crankshaft pulley. The tensioner has a pulley on one end with a bolt head in the center of the pulley. Use the bolt head to rotate the tensioner.
Turn the tensioner counterclockwise with the breaker bar and a metric socket. Pull the belt out from under the tensioner pulley with your other hand. Then, slowly let the tensioner retract until it stops.
Pull the belt out of the other remaining pulleys. Then, pull the belt out of the engine bay and lay it on the ground.
Route the new belt around the crankshaft pulley. Then, route the new belt around the other remaining pullleys by using the serpentine belt routing diagram for instructions.
Rotate the tensioner pulley counterclockwise with the breaker bar and socket. Then, slide the new belt under the tensioner pulley. Slowly let the tensioner retract until it stops. The tensioner pulls all of the slack out of the belt and brings the new belt to the proper tension. Remove the breaker bar and socket from the tensioner pulley.
Inspect the new belt to ensure that it is seated inside of all the accessory pulleys as directed by the diagram. Then, crank the engine and allow it to run for about 15 seconds. Turn the engine off. Inspect the belt again once more to ensure that
the belt is still around each pulley. Close the hood.
Thank you for using Fixya!
