just try the menu to auto program with signal connected to the set, try to use the remote to directly go to a channel, if that fails something is wrong with the set, lastly connect to the audio/video connections on the set if it has them to see if set works in that fashion.
IN BOLD FOR EMERENCY COMPANY!!!! YOUR T.V. COMPANY TURNED OFF YOUR CHANNLES YOU NEED TO DEMAND A REFUN OR YOU JUST GETTING NEW CHANNLES OR YOUR NOT PAING BILLS!!!!! =)
sounds like the little button switches are leakey they are mounted to the board and are very small may need to replace them. They are right behind where you push the power on channl up down and so on buttons on the set.
well first thing to do is this the only tv thats connected to the cable? if it the only one i would call the cable company and have them up the db level. if you have more than one, you'll have a splitter that splits the cable that could be causing your problem, change it out will a new lower db one. another thing could be happening is the cable connector on the end could be failing so have the cable guy replace all those too.
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
