Cleaned the machine to get lint out and put it back together and now my feed dogs won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Something is not put together right, (like the part that was dropped when you took it apart) take it back apart and figure out how the feed dog drop mechanism works... and put it back together correctly.
SOURCE: I have a Brother 98-Stitch
I dropped my feed dogs and when I pushed the button to bring them back up, it wouldn't work. I did discover that when you put the button back to the up position and start sewing, the dogs come back up automatically.
SOURCE: I took my maching apart to clean the lint out and
most likely the bobbin case is not aligned correctly .Insert the bobbin case so that the projection on the boobin case aligns with the spring.
SOURCE: feed dog wont feed the fabric
Remove the needleplate and clean between the teeth of the feeddogs.
Ensure the feeddogs are not lowered for free motion sewing.
Don't know the make/model to be any more specific, so post back here or to the Contact Us page at
www.bargainbox.com.au if there is more to do.
SOURCE: after i took off plate and cleaned all lint out
Call brother customer service at 1-877-276-8437 or check out the brother-usa.com website for your manual download for free
SOURCE: I cleaned my machine, but
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
