Re: I have done that, and i know where to put the belt on...
With the hood off you should see a metal shaft sticking out from the motor about 2" (directly below the handle) this is what turns the brushroller. It should be fairly obvious. I've never seen one break, so thats unlikely. Unless the motor housing melted. It only requires taking off the hood to change a belt on them.
First we need to know what brand and model your vacuum is. But usually you would make sure your vacuum is unplugged. Flip it over and look at roller brush part of the vacuum and find the screws that can be unscrewed to remove the cover of the rotating brush. Once that is off, you will find find a belt on the side of the roller that will need to be removed if broken. You will need to pull out the roller and put the new belt in and stretch it to the motor part which will sping the belt causing to spin the roller brush. Then reassemble and screw cover. Plug vacuum and happy cleaning !
This one is so easy! Well, relatively. First, make sure the vacuum is unplugged. Turn it over and you will see that on the rollers a cover. This cover should have about 4 screws holding it on. Unscrew and remove the cover. Note how it was put on. Take a look at the roller brush ends where it goes into the sides of the vacuum. Pull the roller straight out, noting how the pegs that hold it into the vacuum are situated. Take the broken belt off. It might be attached to one side of the roller. Note which side it is on and which side of the vacuum it is on. If it's not attached, no problem, just note which side it should be on. Now, on the bottom where the belt goes around, should be a silver peg that the belt slides over. Sometimes it's hard to see, but it's there. Take the broken belt to the store and match it up to a new one. Some are thinner than others, smaller or rounder than others. Be sure to get the right one. Now, back home, comes the hard part. Put the new belt on the proper side of the roller, only. Try and get the roller back into the vacuum snugly and secure, that's the hard part. Once you do that, holding the roller with one hand, snug against the vacuum, pull the belt down and slide it onto that silver peg. If it needs to be twisted on, do that, but it probably doesn't need to be twisted. Those are mostly older Hoovers. Once you have it on the peg, move the roller around with your hand to settle the belt into the proper position. Don't get upset if the roller pops off, it does that on occasion. Just put it back on and put the belt back on the peg and the rest. Mumbling helps:) With that done, replace the roller cover and you're done, Bob's your uncle! Plug the vacuum in and have at it. Oh yeah, change the bag or empty the bin if necessary so you have a clean start.
Check to see if there is hair or string or something preventing it from moving. Or, you might have a button or something that stops the roller from moving for suction for the hose only if it detaches for use that way. If it's not that, unplug the vacuum and see if you can move the roller by hand. If not, take the roller off by unscrewing the shield, probably 4 screws and check to see if the pegs that hold the roller in are in properly or broken. Rollers aren't expensive. If it's broken, just replace it. But, I'm thinking that there is something like string holding it. Another thing might be the belt is broken. If that's the case, do this:
First, make sure the vacuum is unplugged. Turn it over and you will see that on the rollers a cover. This cover should have about 4 screws holding it on. Unscrew and remove the cover. Note how it was put on. Take a look at the roller brush ends where it goes into the sides of the vacuum. Pull the roller straight out, noting how the pegs that hold it into the vacuum are situated. Take the broken belt off. It might be attached to one side of the roller. Note which side it is on and which side of the vacuum it is on. If it's not attached, no problem, just note which side it should be on. Now, on the bottom where the belt goes around, should be a silver peg that the belt slides over. Sometimes it's hard to see, but it's there. Take the broken belt to the store and match it up to a new one. Some are thinner than others, smaller or rounder than others. Be sure to get the right one. Now, back home, comes the hard part. Put the new belt on the proper side of the roller, only. Try and get the roller back into the vacuum snugly and secure. Once you do that, holding the roller with one hand, snug against the vacuum, pull the belt down and slide it onto that silver peg. If it needs to be twisted on, do that, but it probably doesn't need to be twisted. Once you have it on the peg, move the roller around with your hand to settle the belt into the proper position. With that done, replace the roller cover and you're done, Bob's your uncle! Plug the vacuum in and have at it.
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Your belt is broken and needs to be replaced. Turn this brush side up. Unscrew the cover plate and you will see where the belt goes. Pull out roller, put on new belt, put back together and there you go.
The belt replacement can be done in just a few easy steps. You're going to want to turn the vacuum on it's side to access the base of the unit. Unscrew the bottom of the vacuum and remove the brushroll. Make sure to remove any string or clumps of dirt that could have caused your old belt to break. Stretch the belt with the brushroll until it can be put into place. Secure the bottomplate back into place. That should do it!
It is quite easy. Just take off the bottom of the vacuum encasing the roller brush. It should snap off or you may have to unscrew some screws and lift the cover off. Then remove the roller and clean it while you have it out. Now put the new belt on the motor shaft or pulley and slip the brush into the belt. Then replace the roller brush pulling the belt tight. Replace the cover and clean house.
Replacing a Belt on an Upright vacuum can vary from model to model, but it is basically going to be the same for most upright models.
First you will need to access the belt. Most upright vacuums this is done by turning the machine upside down, and most you'll need to remove the bottom plate by unscrewing (usually 4) screws that hold the plate on. You should see screws that are closest to the actual roller brush, simply remove these screws, and take the bottom plate off. If the machine is a Eureka, or Kenmore, the top agitator housing will be removed from the top of the vacuum, not the bottom.
Once you have removed the bottom plate, or top agitator housing, you should be able to see the belt (or broken belt) along with the roller brush. Remove the broken belt. Make sure that you purchase the correct belt by taking the make, and the model number (located on the back or bottom of the machine). Please note that a broken belt may be 4-5 inches longer then a new belt, as they stretch a lot before they finally break.
Once you have the new belt, you will need to remove the roller brush. Pay attention to how the roller brush fits into the agitator housing, usually there will be fittings on the end of the roller that have to be put in a specific place, or in a certain way to work right. After the roller brush is taken out of the machine, you will need to wrap one end of the belt around a metal pulley on the opposite side of the roller brush. Most pulleys are located where the main housing (handle part) of the vacuum meet the the agitator (floor part) part of the machine. Anyways, wrap one end of the belt around the pulley, and then put the roller brush through the other end of the belt. This is where you'll need to put some elbow grease into it. You'll need to stretch the roller brush and belt so that the brush and belt are stretched back to the place where you took the roller brush out of the vacuum.
Once you have replaced the roller brush with a new belt around it, pull the belt a few times to make sure that the brush spins while you are pulling it, to ensure that the belt is not pinched, and is spinning freely.
I hope this helps. Here's a video showing how to replace the belt on a Hoover Windtunnel Self Propelled model; Feel free to email me if you'd like to send me the model number of your vacuum, this way I can be a little more specific, and give you part numbers. I have all belts for all vacuums in stock. Email; [email protected]. 1-866-468-2288. You may also chat with me by going to our website, www.govacuum.com, and clicking in the top right part of the page. Thanks!
