Peter CW, Mark with Motorola Support says, "The S10-HD Headset battery cannot be replaced." But, since you have suggested to try eBay to find a repacement battery, this makes me assume that the battery CAN be replaced. If so, I would like to know how to do it.Peter CW, Mark with Motorola Support says, "The S10-HD Headset battery cannot be replaced."
You can't post conmments that contain an email address.
You should be very careful charging any battery that heats up to the point that seems like it is overheating. Newer batteries are lithium ion or polymer and can cause fires when they get too hot although the polymer is supposed to be less susceptible. You should get a new battery if you're sure you're using the correct charger made for your device.
The Lithium batteries that are provided with the camera will supply approximately 200 images. The Ni-MH batteries will provide approximate 100 shots per charge. The B-10LPB Lithium Polymer battery will allow 500 - 700 shots per charge and can be recharged approximately 500 times. B-12LPB Lithium Polymer Battery will deliver twice the power allowing 1000- 1400 shots per charge and can be recharged approximately 500 times. The Alkaline batteries, although can be used, is not recommended due to very low battery life.
You can use two LB-01E 3V lithium batteries, four B-01 4PE AA Ni-MH batteries (BU-40SU charger and batteries), four AA Ni-CD batteries, four AA Alkaline batteries the B-10LPB Lithium Polymer Battery or the New B-12LPB Lithium Polymer Battery . Please note: the B-10LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-30 LBS kit, and the B-12LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-32 LBS kit.
oakleythumprepair.com
