I need to setup the scanner, i have the manual and i tried to configure with some codes but i cant see the result in the screen, if someone can help me to tell me which codes i need to select to configure in the right way the scanner thank you
SOURCE: ENTER after reading a barcode
look on page 200 (5-150) and scan the barcode there, then scan a four digit barcode you print based on the code in the appendix. I see 7013 on page 243 as the Enter key. also look at the code on 203 for the <data><suffix> format.
I would do these steps....
1. scan the code on page 200
2. scan the barcode you create of 7013
4. scan the code on page 201
5. scan the code on page 203
6. scan the code on page 206
Does that help?
SOURCE: Symbol LS2208 RS232
Go to the LS2208 quick start manual scan the "Set Defaults" barcode and it will return the handheld to factory default.
SOURCE: Can't install Symbol LS2208 barcode scanner on a PC (Wedge cable)
You will need to scan the barcode that configures the LS scanner to use keyboard wedge or even the set all defaults barcode. You will be able to find both of this on the product reference guide that you can download from www.symbol.com in the support page.
SOURCE: Need User Manual for Symbol Barcode Scanner
This is the LS400xi Product Reference Guide. This contains all of the standard programming barcodes.
The Advanced Programmer's Guide contains barcodes for modifying the way the scanned data is sent.
