LG 37LD450 37 in. TV Logo
Tracey reilly Posted on Aug 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote control doesn't work
Remote control has stopped working
Anonymous
Level 3:
Top Expert:
  • LG Master 14,553 Answers
  • Posted on Aug 30, 2012
Anonymous
LG Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715307
Points
48227
Have the remote itself first checked---most tv shops have a tester--point remote at it and press buttons and it reacts-----Many digital cameras will react on their display screen in a very dark room in the same way.
If remote itself tests good the set has a receiver that takes the signal from the remote and it may be bad.
4 Related Answers
Anonymous
  • 2098 Answers
  • Posted on Aug 22, 2011
SOURCE: Remote won't work. Tried new
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Anonymous
  • 2382 Answers
  • Posted on May 08, 2011
SOURCE: My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Anonymous
  • 14553 Answers
  • Posted on May 21, 2012
SOURCE: Side control doesn't work
check the owner manual (LG site has them if needed) to see if the unit has a lockout feature which will disable the side or control buttons .
Anonymous
  • 1182 Answers
  • Posted on Jul 23, 2012
SOURCE: Lg 42lg30 remote doesn't work
Incompatibility. You may have to go for its original remote. Look through the operation manual and buy a replacement of the correct model.
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
1helpful
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
3answers
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
3answers
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
My TV remote control has stopped working. I've tried changing the batteries but it still doesn't work. Any tips or do I have to get a new one?
Check for rusted battery contacts due to leaked batteries. Clean them with polish paper or blade. Due to leaked batteries it is quite likely that the wires connecting remote control pcb & battery contacts are cut off.
sonsunny
I need a new remote for my rca t.v. the phone number in the manuel does not work who do i call
Throw your RCA TV out the highest window available. Every Phone number for service reroutes you to another wrong number or website that can't help you. I finally got a number for corporate headquarters--just to get a replacement remote for the 6 month old one that stopped working--- they actually did send me a new one. IT DOESN'T WORK! Worst customer service ever, RCA products have gone to hell and warranty is meaningless. Boycott and tell everyone you know not to buy their **** products. Drive them out of business so they stop stealing people's hard earned money.
It runs 5 to 10 minutes, then it stops. When I press the remote control boton, it works again for 5 to 10 minutes and then it stops. So I need to repress the remote control again to make it starts.
I guess you are having a problem. That model dehumidifier doesn't have a remote control. As a matter of fact, I'm not aware of any model dehumidifier that has a remote control. A remote would be useless. Now, some portable air conditioners have remote controls. Is that what you have? A portable A/C unit? Please advise. Thanks.
My logitech 890 stopped working my components. The lights are on the remote. The help key goes through it's normal functions. The remote appears to work but components do not respond. What do I do?
I would reset the remote to the factory conditions and then reload your specific configuration onto the remote. If that doesn't work I would suggest RMA'ing the remote with logitech if possible.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
