Samsung Vitality SCH Logo
shay Posted on Aug 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i make a three way call - Samsung Vitality SCH
Anonymous
Level 3:
  • Master 1,216 Answers
  • Posted on Aug 30, 2012
Anonymous
Master
Level 3:
Answers
1216
Questions
Helped
308163
Points
3630
tip
Quick horizontal lines in Word 2007 document
<span><span> <p><br /><br /> <p><span>1.<span> </span>If you want to add a simple straight line, type three dashes (---) and press Enter on the keyboard.</span><br /> <p><span> </span><br /> <p><span>2.<span> </span>For this style of a horizontal line, type three asterisks (***) and press Enter.</span><br /> <p><span> </span><br /> <p><span>3.<span> </span>Type three underscores ( ___ ) and press Enter to get this line:</span><br /> <p><span> </span><br /> <p><span>4.<span> </span>Type three equal signs (===) and hit Enter to get this line.</span><br /> <p><br /> <p><span> </span><br /> <p><span>5.<span> </span>Three pound signs ( ### ) and press Enter for this style of line:</span><br /> <p><span> </span><br /> <p><span>6.<span> </span>Typing in three tildes ( ~~~ ) and hitting Enter will allow you to add this horizontal line:</span><br /> <p><span><br /></span><br /></span></span>
on Dec 02, 2010 • Computers & Internet
3ft to 3yd
What's the question? A yard is three feet, so three yards would be nine feet. Three yards is three times as long as three feet. Three yards is six feet or two yards longer than three feet.
My Power Chair is flashin three code
hi, if it 's stays three pause three then the error "Left Motor wiring fault" , now I suggest you remove the lead from the controller and refit check the connections are clean and tight.
Regards
I have an aircompressor that I'm need to connect to a power supply. I'm in Iraq and not sure of the wiring. The motor is 380volts, and it has three leads going into the motor. I just need to know if I need...
If motor is 380 v three phase, then all three wires will be connected. Usually, three phase motors do not have capacitors. If motor turns the wrong direction, just switch any two leads. If the motor has capacitors then do more research on wiring requirements. There may be more connections inside of motor and only three exit the connector box.
How to wire three-phase heater -model-berner mark 1 56e i have 220&110 the heater has three wires blk.rd.bl.
If this is in a home or garage you can not wire three phase as residential wiring does not have three phase, commercial buildings have three phase. Not saying it is not possible to get three phase to the house, but this could be quite costly. My suggestion is to purchase a 220 volt heater. Do not destroy the packaging it came in so you can pack it up and return it. Sorry for the bad news.
5helpful
How to change the spark plugs on peugeot 406 v6 3l coupe is this straight forward like a 4 cylinder car
1. Spark plugs removal
1.1. Front cylinder bank spark plugs removal:
1.1.1. Disconnect the battery from car terminals.
1.1.2. Remove the engine plastic cover.
1.1.3. Disconnect the ignition coils electrical supply cable and all three coils connectors.
1.1.4. Remove all three ignition coils screws.
1.1.5. Remove all three ignition coils out from cylinder head.
1.1.6. Remove all three spark plugs out from cylinder head (straight forward).
1.2. Back cylinder head bank spark plugs removal:
1.2.1. Remove the inlet manifold out from cylinder head.
1.2.2. Disconnect all three ignition coils connectors.
1.2.3. Remove all three ignition coils screws.
1.2.4. Remove all three ignition coils out from cylinder head.
1.2.5. Remove all three spark plugs out from cylinder head (straight forward).
2. Spark plugs installation
2.1. Refit all in reverse order.
2.2. Spark plugs tightening torque = 2,8 +/- 0,3 daN.m
2.3. Ignition coils tightening torque = 0,8 +/- 0,2 daN.m
Find the three consecutive numbers? such that the smallest is 57 less than three times the largest
Let the three consecutive numbers be x, x+1, x+2.
Now, the smallest is 57 less than three times the largest...
=> x + 57 = 3(x + 2)
=> x + 57 = 3x + 6
=> 2x = 57 - 6
=> 2x = 51
=> x = 25.5
=> x, x+1, x+2 = 25.5, 26.5, 27.5
So, the three consecutive numbers are 25.5, 26.5, 27.5.
1helpful
How many spark plugs (spark plug wires)
If it is the 3.5 V/6 three plugs in the front and three in the rear you can't see the three in the rear. you have three coils on the front plugs each coil splits into three wires for the rear plugs.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
