SOURCE: Cannot turn date stamp off and date keeps resetting
Try removing battery from camera then wait 10 seconds before installing. This action resets camera.
If no work, locate your camera software version. Procedure should be in manual, else could probably find it in a google search. Then locate latest version with a google search, or panasonic camera website, or call to customer service and ask.
It you do not have latest version, ask customer service how to download it.
SOURCE: Not getting date on downloaded pictures
The date and time (and a lot of other information) is always stored with the picture file in what's called the EXIF data. By default this is not shown on top of the image since neither the camera nor any photo viewing program knows which portion of your photograph is unimportant and can be obscured by this data.
Any photo editing program should be able to show you this data, probably in a separate window. Most photo printing software likewise can print this data, either on top of the picture or in the margins or on the back. Please refer to the documentation for whatever program(s) you're using.
SOURCE: How do I turn on the time and date stamp?
Your camera won't deface your pics by scrawling a string of numbers across them. However the date and time (and a lot more) are stored with each file in its EXIF metadata. Just about any photo editor/viewer should be able to show you this data. If you want to print the date, please refer to the documentation for whatever program you use to print your pics. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
SOURCE: does anyone know how to switch the date and stamp off on my lumix tz20
Press the MENU/SET button. Select REC. Select DATE STAMP.
