My mm6 lcd display has dark lines through half the screen on and off. It seems to be a common problem on all copy's of this model that half the screen appears damaged or blank, on and off. some days it does and some days it doesn't. I would like to know if there's any fix for this problem that can be done at a local shop instead of having to go through a hundred channels to get a solution
SOURCE: The LCD has lines on
The defect is likely failure of the LCD module and the connections to the glass sandwich... it is likely fatal to the module... If you are adept with tools a bit, you can probably replace it yourself... You have to go slow and be careful to keep track of where stuff goes.
One has to be real careful to not damage the ribbon cables that connect between the upper and lower shell. I suggest having two people present to handle the shell when opening it. Have a good work surface and organizer cups or bins to keep screws seperate. There will be a LOT of screws from the back to remove to seperate the halves. DO NOT force anything.
You can probably order the part... Call Yamaha America Music support and ask for parts dept to order the part... I suspect it is a bit pricey. While your at it, inquire if they can sell you a service manual for the keyboard... they used to do this for $15 and you could get one with your order. The manual for the Tyros I got is very complete showing all the internal and assembly procedure.
SOURCE: My Yamaha mm6 doesn't work
There is probably a setting that is wrong. The left channel is the default for mono operation. Look in your user manual regarding "PAN" which controls the output going side to side. You MAY be "panned" clear to the right. When you plug into the left, it is the default so in spite of being panned right, they would send signal to the left IF nothing is plugged into right.
