Hi
did you check if the fuse is slow blow or fast blow and if it has the the same current rate?
ex: 3.14 A
anyway if the amplifier is consuming a higher load that means there are capacitors to be changed.
more information would also gives better idea of the problem.
Hope this helps.
First you need to check the wiring to the plug and any fuses. If these are good, Then take the top cover off and look around for an internal fuse. Also keep your eyes peeled for any sign of damage or signs of burnt parts.
overload is protection from very big signal input-or high current output. 1-keep your input signal between -10db-----to 0db. 2-confirm that amplifier power is greater than total power of loudspeakers by 20%(if loudspeaker total power is 8 watt-amp watt must be 10 watt at least.
My solution was actually indeed the output protection relay. What I did was to open up the relay and use contact cleaner and a very fine abrasive to clean the contact surfaces of the relay. After that, the problem was gone!
The way to diagnose this for me was to run the amplifier open until the problem recurred and to simply tap the relay's box. The sound came on immediately, and I was convinced.
