Leica Digital DISTO D3a 100M Laser Distance Meter Logo
Timothy Boyle Posted on Aug 31, 2012
What's your problem?the on button is turning off my Leica Digital DISTO D3a
Switches on ok - but when I try to hit the on/dist button to take a simple measrument the unit switches off
Not Brett
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 30, 2013
Not Brett
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8541
Points
I was able to resolve this problem by replacing the batteries
  • L Zukus
    L Zukus May 30, 2016
    Thanks, Not Brett, battery on D 330 showed 66% and would turn off when taking a measurement. Changed battery like you suggested and everything works fine.
When I turn on my Leica Disto D510, the screen flicks on - no display and then I cannot turn off, so to turn off I need to remove battery. Can Disto be re booted? CRA
first off it is not a computer at all why post this thing to computers? let it sit for 24hours,batteries removed.l .
use fresh Type AA 1.5 V. batteries and see it work
never not try new batteries on any battery device that acts oddly.
you paid $600 for this thing , OMG too much.
worth $100 + $500 name Leica
Leica L Leica Disto D510 (E7500i) 650ft/200m Laser Distance Measurer w/ Bluetooth and Disto Sketch App for iPhone/iPad - Red/Black
My Leica Disto D510 screen is broken, does anyone know the part number to replace?
Contact Leica themselves, or try your local camera repair facility.
What does error 270 mean?
There is no error code 270 listed for a Leica Digital DISTO D3a 100M Laser Distance Meter.
Are you sure that's the code?
Or do you have a different make or model of laser distance meter?
Leica disto
Low battery. Mine does that when batteries are too low to operate the laser.
Aug 20, 2013 • Optics
1helpful
Leica Disto D3a shows ERROR 220
I had this exactl problem and resolved it by replacing the batteries
Have a Leica Disto basic and need to know how to change measurement from m to ft.
Press and hold the circle button down, after a few seconds it will flash 'beep on/off', dont stop holding it down, it will then cycle to 'units', press +/- to change between metric and imperial, then press the = button to store. If you keep holding it down you can set the reference pont (where the measurement is taken from, the back, middle or front edge of the machine) add an offset (add take away from the displayed dimension), and you can also reset the machine.
1helpful
I have no manual, how do I get the distance number to appear?
You can download a manual at http://distagage.com/downloads.html
but simply, to get the distance to appear, turn on the unit with the large red ON/DIST button, aim the red laser dot at your desired target, and press the ON/DIST button again. The distance will appear on the display screen.
Greg DeTray, www.distagage.com
1helpful
Leica disto A3 button broke
Mike,
Leica does not sell replacement keypads, if the unit is less than 2 years old they will cover it under warranty. Contact the dealer you bought it from and they can handle the warranty exchange. If it is over two years old, it is out of warranty, but they offer a "repair" option, which will replace your damaged A3 with a new D3 for about $215. If you bought it from a reputable dealer, you shouldn't have any problem.
Hope this helps,
Greg DeTray
www.distagage.com
29helpful
3answers
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Top Leica Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Leica Measuring Tool and Sensor Expert? Answer questions, earn points and help others
