No red LED, does not respond to remote, nothing. The board does not look like anything is burned, no bulging capacitors. I replaced the two replaceable fuses (6.3 and 3.15a ceramic) and nothing. I have a multimeter and some tools.. I would like to fix this.
SOURCE: Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
SOURCE: LN-T4061f samsung lcd no backlight, no sound, no picture
Replacing the capacitors would be a good start. Replace all the ones with the same capacitance and voltage rating even if they do not look bulge.
Let me know if you require further assistance.
SOURCE: First of all, I really
Would troubleshooting chart of LN-S4052D help you to diagnose problem?
Let me know to send you pdf file of troubleshooting for no power problem, it has details to test what volts on what points.
Thanks.
Below is first page image of related service manual just for reference.
SOURCE: We had a power surge
Hello
Lightning will have Trillion Trillions of volts, when it discharge to earth. Whatever type of surge protector we use, cannot withstand it. Even though other devices are safe, as you say, not the case of TV. The TV is connected direltly to mains supply voltage, even though it is in OFF state, there will be supply to the regulator board to keep one 5VDC supply, provided to work the memory and V-Chip section. Unless, all the memeory will go out, and you have to retune and reset the TV everytime you switch it ON. In fact, TVs power switching regulator side is working 24 hours a day. When lightning occurs, a sudden very high voltage, which cannot be suppressed by the surge protector [any surge protector in present market can supress upto 100 or 1500VAC peak the most]; and will get into the power supply section. Eventhough a trillionth part of a samm intensity lightning can damage the power retulator section, as it is designed to work in between 110 to 280VAC the most.
The power supply section inside your TV has now damaged. It is best to replace it as a catd basis, rather than making 'surgery' to it. Some other components in it also be got damged, as we cannot detect now, and will cause trouble in future, and make more "pocket leak' to you. So repalce it with same type and number, the number will be printed on its PCB. The orginal supply board can be had from Samsung Authrised Service center at your town. Just keep the board in hand as sample, when you go to buy a new one. OK.
SOURCE: -Plugged into wall -Red LED on -Remote
Did you ever got the solution for this problem?
I have the same, I did notice that when I lift my tv from the bottom, attached to the wall support the tv turn on by itself, weird no?
