I have forgot my user account password hoe do i get a new one
For xp
Select the user account you wish to change.
Select "Change My Password." If you wish to remove the password, select "Remove My Password."
Enter the existing password in the first field.
Enter your new password in the second and third fields.
Enter a password hint in the fourth field.
Click "Change Password."
Click the "Start" button.
Double-click "User Accounts."
hope this helps
Unfortunately they have forgotten their password.
So I actually bought some time ago a password reset program.
It allows you to remove password and either leave blank or enter new password is settings for your account on windows PC, windows 8, xp.
SOURCE: cant log on forgot user account password for hp pavilion zd8000
Oh, you must be an Administrator, right? If there is another Administrator account on the PC, it can restore your password through User Account Settings -> Manage Another Account.
If not, I have a complex way. First, restart the PC. When it shows the HP logo when booting up, press the button for Setup (it is shown at the bottom of the screen, and it is F8 on my HP tx2001au).
Now, don't get scared by what appears. It looks a bit complex, but it is very simple and easy.
Navigate using the keyboard. Press the right button to move to the Security section. Here, press Enter on the Administrator Password option. Now enter and confirm a new password and you're done.
See the bottom of the screen for the button for 'Quit Saving Changes' and the computer will reboot. Now, I guess you can enter the new password.
If this doesn't work, see online for ways to reset a password in Vista. There are some softwares to burn to a CD and use.
If it is an XP, I guess there is nothing to do. Just press Ctrl+Alt+Del on the logon screen to see the classic logon screen. Type in the username 'Administrator' without quotation marks and the password blank. Press Enter and enjoy.
SOURCE: system cannot log in to my user account
In case you have problem with your pass restart your computer, log in as administrator (the
default pass is blank) and change your account's pass to a proper one, easy for you to remember.
Stelios.
SOURCE: reset my password
Go to Start, run, enter cmd click ok
enter the following:
net user (username) (password)
must be logged in as Administrator
Sincerely,
Ryan Deschaine
Systems Engineer
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: [email protected]
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
SOURCE: I forgot my user account password and cannot even
Follow the steps below to quickly find the administrator password on your computer!
1. Try leaving the password blank. More often than not, the Administrator password doesn't exist at all! Just press Enter without typing anything when asked for it.
2. Enter the password to your account. Often times, depending on how Windows XP was setup on your computer, the primary user account will also be the administrator user account.
3. Try to remember your login password. If you installed Windows XP on your computer yourself, you probably set the administrator password during the Windows XP installation process. If that's true, you might be able to make really good guesses at what the password might be.
4. Have another user enter his or her password. If there are other users that have accounts on your Windows XP computer, one of them may be setup with administrator access.
5. Recover Windows XP administrator password using a password recovery tool. Password recovery tools are software programs reset Windows XP password without reinstalling the OS.
6. Perform a clean installation of Windows XP. This is a last resort option. This type of installation will completely remove Windows XP from your PC and install it again from scratch. If you're just curious about your administrator password, I wouldn't suggest this extreme solution.
However, if you're needing the windows password to access diagnostic tools and this is your last effort to save your PC, performing a clean install will work. Keep in mind that it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
More information and Tutorial to visit from ( http://www.windows7password.net ).
SOURCE: I forgot my user password so I can't get in to
Create a password reset CD on another computer, then boot from CD in
the locked computer, and it will allow you to reset your password.
Click HERE
to get the software and read the instructions carefully.
my buddy's sister makes $70 /hour on the computer . She has been out of a job for 8 months but last month her paycheck was $14224 just working on the computer for a few hours. check my source
click here...........>>> www.profitclip.com
