My washer started out not spinning. now it fills up agitates the load, then stops on the rinse cycle.then it will not drain or do anything.please help.
I had the same problem with this washer. It was the lid switch.
I also had the lid switch problem. I got it to work by messing with it for a few seconds.
Jewel 42 I had a similar problem with mine, it wouldn't drain or spin. It was the sensor/lever that lets the machine know that the lid is closed... the screw casing that held it in place had broken... I tied it back in place covered the string with duct tape and now it works fine... or at least it did until the pump cracked this week.
Check filter and check no foreign object in pump impellor.
SOURCE: My whirlpool imperial ultimate care fills with
Problem with PCB, please call service Engineer.
I have Imperial series clean touch washer and the agitator suddenly stopped and water drained out, I tried again to fill with water, at the level water sopped but the agitator wouldn't start and water drained off. What could be the problem?
i have Imperial series clean touch clothes washer from whirlpool and the agitator stopped suddenly and water drained out, tried again to fill with water, it reached it's level but the agitator didn't start and water drained out, what could be the problem?
after the wash cycle, it only drains about half the soapy water before it stops draining... and fills with rinse water. so you never get a complete rinse and clothes feel and smell like soap.
Exact same problem. After agitate mode machine won't go into rinse mode.
My washer will occasionally not spin all of the water out at the end of the cycle. Right now I am able to run it through the spin only cycle and it will spin the remaining water out. Any ideas on why it will sometimes do this? (I have the same load amount in each load)
Thanks!
Tammy
The washer stops at the rinse and spin cycle. Now it is full of water and will not drain or spin or empty. Plus there is a funny odor coming from the machine. I think it might be the motor is bad. Your opinion.
My washer does not stop filling up
