I have a conect it model# rm400 i need a code for a sansui tv
Hello not sure what your remote model number is but i have instructions for the ER-440 and the codes given for the sanyo tv are as follows...
0141, ...0601, ...0981...1111,...1691,...2091,...0151,...0801,...1021,...1291,...1741,...2251
,...2551,...04011,...0821,...1101,...1351,2051
Hope this helps
happy new year.
Hi, I lost the remote control codes rm400 i have a tv philips and i can not find the codes, would you help me? thank you
I need codes for magnavox blue ray player
Codes please from a connect-it er-440 remote to a matsui dvd player------------------------------------cheers
SOURCE: In need of tv codes for ge romote control
You don't need a code. Just follow the instruction as follows:
1. Tun on TV
2. Press and hold "code search" until light stays on, then release.
3. Press TV botton
4. Press on-off repeatedly until TV turns off
5. Press enter.
That is it. It works for me.
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Looking for codes for an Admiral TV
press set. press tv. try one of these codes. 0506, 0311, 0612, 0002, 0428, 0802, 0412,0619
oh then press power . if it goes off you are set.
