SOURCE: my washer will fill up but won't spin out and
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: My washer is not draining or spinning. it is
Hi, Thank You for your question. What I would like you to do is take a shallow pan, and set it below the filter down below in the front. I you don't see it, remove the kickplate. Its round and looks like a handle. Slowly turn counterclockwise until water starts to drain into pan. Drain pan when partially full. Repeat this process until no more water comes out. Then unscrew filter and remove and clean. Reinstall and make sure its snuggly tightened down. Should solve your problem. Have a good day.
SOURCE: agitator won't spin and water
Hi
Try these things first.
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here.
If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
SOURCE: grinding noise from washer...sounds like
Thanks for choosing FixYa and welcome. Since your hear grinding and there is no spinning or draining, it may be the motor drive. The motor drive controls the spinning and draining. You need to find out if the motor is turing on. More then likely, your issue is there. Check your water pump also. Check for clogs and check the pump belt. You may have a frozen belt pulley. A bad lid switch can cause the washer to act up but it wouldn't explain the grinding. I believe it is related to the motor but check these other parts anyway.
SOURCE: Maytag washer mav4757aww was agitating a little
Unplug the unit and remove the front panel and look at the space between the motor and transmission find the coupler that connects the two together this could be broken. You may have to lay the unit on it's back to check this out. It's a cheap fix if its the coupler. Let me know.
