The washer stopped mid cycle, now when i try to turning it on again it makes those weird buzzing noise but it still wont spin... Please help
SOURCE: MAH2400AWW washer won't drain
pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
SOURCE: making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
rachet device under agitator is stripped.
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
