Question about Dewalt 7.2-18.0 Volt One Hour Charger
Change a dewalt charger dcb100 to 240V input
Dewalt rapid charger DCB100 rebuild from 110V input to 240VAC.
5 Suggested Answers
6ya staff
SOURCE:
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: 18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Posted on Jan 30, 2008
emissionwiz
Marvin
  • 85219 Answers
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: convert 2 pin dewalt charger to 3 pin how
By 3 pin do you mean the third pin being a ground. If so that charger does not have anything internal to ground to. It is a 120Volt Double insulated tool. Let me know if you are trying to do something different.
Posted on Jan 29, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Will DeWalt charger work on 120V 50Hz?
I don't think that would be a problem, For schematics I would go to Dewaltservicenet.com and type in your model number usually in the center of the site and download a breakdown. Let me know if i can help more.
Posted on Feb 13, 2009
18 volt charger (Dewalt)
The DW9116 is actually a 120 volt charger so it should cope with 130v AC supply, what is the supply from?
It is normal for a standard 110v supply to run at around 117V
See THIS INFO on power supplies
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
Dewalt DCB105 li-ion XR Battery Charger 10.8V - 20V
For Battery Type: Ni-Cd Ni-MH
Input Voltage: 110V-240V
Smart Charger for Dewalt 10.8V ~ 20V Li-ion Battery
For Brand: DEWALT
Color: Black
Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
http://www.drillbattery.com.au/charger/dewalt-DCB105-charger.html
May 04, 2015 | Dewalt Drills
Will my 240v charger work on 110v
Can't say for certain, but there are specific 110V and 220V versions of DCB101.
None are labelled 90-220VAC as would be normal for universal voltage equipment.
If you operate 110V equipment on 220V then you will most likely damage it with overvoltage.
If you operate 220V equipment on 110V then you will most likely damage it in over current or have it simply not work.
It is possible that the charger is universal, just not labelled as such.
Send DeWalt an email.
Mar 29, 2015 | Dewalt 12v Max - 20v Max Li-ion Battery...
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Bought 4 days ago,but the battery do'st stay chARGED very long.why?
It is new, need to charge/discharge several times to achieve optimal life.
May 23, 2014 | Dewalt Dcb100 12 Volt Max Fast Charger
Convert Dewalt Charger DE 9116
It is not feasible to convert it internally.
Jul 15, 2013 | Dewalt 7.2-18.0 Volt One Hour Charger
Changing Dewalt charger from 120V to 240V
all i can say get a seperate step up transformer fron 110v to 220v.then just plug in charger to the step up transformer. make sure that u have 2 consider the frequency in ur country.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt 7.2-18.0 Volt One Hour Charger Logo
341 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
