Minolta X-700 35mm SLR Camera Logo
Michelah Mae Posted on Sep 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Minolta isn't taking photos at all
My Minolta X-700 isn't working at all. I look through the viewfinder and it is acting like it takes a picture. However, when I tried to get the film developed there was nothing on there. I believe everything was set in proper order and my film was loaded correctly. Is there absolutely anything that I can do to fix it without having to ship it off to get it repaired?
Tony Parsons
Level 3:
  • Minolta Master 6,405 Answers
  • Posted on Sep 05, 2017
Tony Parsons
Minolta Master
Level 3:
Answers
6405
Questions
Helped
1652193
Points
20272
Next time you load a film, leave the back open and watch as the film goes on to the take-up spool. You'll lose a couple of frames, but that's better than the entire film. If it is not loading correctly, then a prohibitively-expensive repair is called for. Replace it.
4 Related Answers
poolseman
zdenek vajdak
  • 206 Answers
  • Posted on Oct 11, 2007
SOURCE: Minolta X370 film loading problem.
 First make sure your batteries are OK , camera will not work without two 1.5 v batteries. If your camera still doesnt work this is probably  because the shutter is cocked but you cannot release the shutter and that is why you cannot advance the transport mechanism. The shutter release mechanism needs repairing first. SREMEDY : take bottom cover off ( 4 screws ) and locate 220 mf 6v capacitor ( it is the only one in this part of the camera , cant miss it ). Replace the capacitor while you keep an eye on the polarity ( indicated on the casing of the capacitor ) and you camera should work fine ( dont forget camera needs  two 1.5v  batteries to work ! )
Ekse
  • 13435 Answers
  • Posted on Jul 22, 2008
SOURCE: Minolta 7000 internal battery
I would recommend haveing it checked by a camera repair company or a local tech if you know one.
Il look into this though will get back to you.
Anonymous
  • 423 Answers
  • Posted on Mar 16, 2009
SOURCE: Minolta 35mm X-370 stuck shutter
You are probably on the right track with the batteries. Stick some fresh ones in and the shutter should release. Your may need to use the advance lever to re-**** the shutter and drop the mirror down. You could also try removing the lens and manually pushing the mirror down to see if it stays in the down position.
Anonymous
  • 185 Answers
  • Posted on Jul 26, 2009
SOURCE: Film Advance won't work on Minolta X-700
changing the batteries have no effect on film transport, just a coincidence. take the bottom cover off and check the white plastic gear on the film take up side of the camera. if it is broken your X700 may not be repairable as no new parts are available.
push the re-wind button in and try to charge the shutter again. remove film first. if it still just goes part way then a gear is stripped. try to find a camera repair shop that may have good used parts available.
The inside mirror in my minolta xg-a wont stay down and also my film lever wont advance neither will the shutter close
My minolta x 700 has its mirror stuck half way. I shot a photo at 125 and it just stayed there. Not stuck to top nor bottom just in the middle.
Anyone know the problem? Thanks.
2helpful
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
The photos from my Ricoh Caplio R4 are no longer sharp (they are blurred if anything). Lens is clean & undamaged, I have tried factory reset, new SD card, spare battery (just in case). Thanks in...
you seem to have a similar problem to the one I posted a couple of days ago John. Is your viewfinder image clear before you take your photo? Mine only takes clear shots if I move the sound/movie/camera button up and down a few times and actually see a clear image in the viewfinder before I take a shot. How you cure that is why I posted my query.
Chris
1helpful
Black screen will not take photo
May sound silly but, make sure the lens cap is off. If so, then look to see if the automatic iris is opening when you power on the camera, you will know it is open when you can see the glass of the lens. Fresh/fully charged battery/batteries would be something else to try.
1helpful
Nikon d40x
It sounds like your flash capacitor isn't fully charged up and your taking a photo and there isn't enough power charged up, so your photos turn out too dark. Take a photo, wait for a minute or til you see the flash icon inside the viewfinder lit up and then try taking another photo.
1helpful
Advance lever jam
Yes, If you get metering lights in the viewfinder display that go out when you press the release fully to take a picture, it is the cap.
Black screen cannot take picture minolta dimage a1
i have seen a recall notice on this camera - you can send it sony konica minolta for free repair.
search web for details.
3answers
Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Top Minolta Photography Experts
ZJ Limited
ZJ Limited
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
