The howling (squealing) noise is likely the belt, if I had to make an educated guess. Of all the fixes you could be stuck with, that's one of the easier ones.
The reason I suggest that is because even though it probably isn't washing to its fullest potential either, you wouldn't really notice it, if it's still able to do a little agitation. Once the spin cycle kicks on, the motor applies a lot of power, and if the belt is loose, it'll spin that belt around the wheel, creating a really soothing and serene squealing noise, causing average humans to start seeking sharp objects with which to slice their wrists.
SOURCE: Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
SOURCE: My Maytag Centennial washer jumps around during
Have to keep the loads a little smaller and better balanced. Does not appear to be a particular problem with my machine.
