Lenovo G460 Notebook Logo
Colleen Murphy Posted on Sep 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Granddaughter fooled around and changed password and doesn't know what she changes it to ..ay way to fix it I am nt able to log in at all
Anonymous
Level 3:
  • Lenovo Master 32,281 Answers
  • Posted on Sep 03, 2012
Anonymous
Lenovo Master
Level 3:
Answers
32281
Questions
Helped
7913026
Points
102259
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Can't log in to fb
I hop some one hack your Id and changed your password
you should just click on forget password and change
your password use your id with new password
visit my site
I changed the network to workgroup and shut down the computer. now my password doesn't work because it can't find the network
download and run offline nt password and registry cleaner from here: follow the walk though and you can remove the password and start over. :http://pogostick.net/~pnh/ntpasswd/
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Don't the user name or password for my motorola SB900 can you help ?
That's depends...First, do you have the password to log into the modem? it seems that the default is admin/motorola. If that hasn't been changed, you could log in and remove the WEP key.
In addition, most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't be worry...Or if these all can not work, you can call or ask directly to the customer service of Most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't worry... or if the above ones all didn't work, you can call or ask the Motorola customer service directly, maybe they know the solutions because they produce it!
2helpful
Why can't I log in to my AT&T U-Verse account with my password?
Hi Philip! Thanks for using FixYa.
AT&T has admitted that there is a bug on their database that causes their customers issues with their passwords. How they managed to mess that one up I'll never know.
In terms of getting a fix for it there's a couple things you can do before calling AT&T customer support:
Go through the "Forgot Password" process. Sometimes this will reset the issue, but it's a 50-50 gambit really. Many users report still having issues while some are able to log in. Furthermore, there is the possibility that you get caught in a password reset "loop" where each password reset requires another one.
Either way, this is pretty much your only option before calling AT&T's customer support. It's an issue that unfortunately a) is prominent amongst users and b) usually doesn't get fixed without talking to a support guy.
You can contact AT&T by using their contact page.
Mar 01, 2012 • AT&T UVerse
I forgot the passwork to my laptop how do i reset?
Login on another account that has administrator rights, then change or reset the password for the account you are having problem logging into.
If you don't have other accounts that have admin rights, try to use the "Offline NT Password & Registry Editor", it works on different version of windows even the old ones. - You may download it from http://pogostick.net/~pnh/ntpasswd/- For additional guides about using the offline NT password and registry editor, please visit http://windows-server-training.com/windows-7-password-reset-recovery/
Hope this helps.
1helpful
How can we set a password to the linksys wireless-g boadband router
Power On your router after after Connecting your adapter, turn on the router, wait for few seconds and then connect the router to your PC's Lan Card Port from one of the ethernet ports (not the labelled internet port). Open your internet browser and type in http://192.168.0.1 (if it doesn't work, use http://192.168.1.1) and press enter to open the page, once it's loaded, you'll be presented with the login page, in the USERNAME box, type in admin and leave PASSWORD blank (empty) and then press Enter. Once you are logged in, go to the admin section and change your password. If Admin panel isn't available, you can look for configure or change password.
If the above method doesn't work, click this LINK and follow the instructions. Let me know if you need further help.
Good Luck.
Thanks for using FixYa,
2answers
I have a ZX4931-31e gateway all-in-one. i did a system restore back to factory settings. when it rebooted i was asked to log in and i don't know what the reset administrator password is? i tried...
Have you tried a blank password for the administrator. Just press enter when administrator pops up. If that does not work, try administrator. That should solve your problem.
Thanks for using FixYa!
I am trying to sign in to my yahoomail but can't.
Make sure that your internet connection is not intermittent,
try to log in again and check your password if the caps lock is activated - deactivate first, make sure you have'nt changed your password... if you still cannot log in, try using other computers with different internet provider, if still cannot log in: you will find a link at the yahoomail window that says "cannot access my account" click the link and follow the steps.
4answers
Cant Log on my com. LOST PASSWORD.
This comes from Yahoo but the last time I recovered a lost pass I hooked the drive up as slave on another machine and used a program to search for the pass on the old drive.
Method 1: Take a rest, and try hard to remember the forgotten password
Sometimes, human being is a little weird. You won’t get the thing that you urgently need. So have a coffee, take a snap or even come back after a few days, you may found that you suddenly ‘remember’ your Windows password.
Method 2: Try No Password Administrator Login Backdoor
In Windows XP (not Windows Vista as Administrator account is not enabled by default), there is built-in Administrator user account, that has administrative credentials, enabled by default, and without any password to protect the account from been access. If you didn’t change this Administrator’s password, then try to sign in to Windows XP without password.
Method 3: Reset password from another user account with administrator credentials
If you cannot log on to Windows by using a particular user account, but you can log on to another account that has administrative credentials, follow these steps on how to do the trick:
Log on to Windows by using an administrator account that has a password that you remember. You may need to start WinXP in safe mode.
Click Start, and then click Run.
In the Open box, type “control userpasswords2′, and then click OK.
Click the user account that you forgot the password for, and then click Reset Password.
Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Method 4: LOGON.SCR password reset trick
LOGON.SCR changing administrator or domain admin password hack works on Windows NT 4.0 and some versions of Windows 2000. The simple trick uses Cmd.exe as screen saver that triggered by system when idle, allowing users to access to command prompt to change password.
Method 5: Do-It-Yourself (DIY) third party recovery tool
There are a lot of tools and utilities that can be downloaded and used to recover, reset, retrieve or reveal existing password. These password reset or retrieval utilities, free or paid, are usually a Linux boot disk or CD that able to comes with NT file system (NTFS) drivers and software that will read the registry and rewrite the password hashes, or can brute force crack the password for any user account including the Administrators. The advantage is that there is no fear of leaking your password to outsiders, while the process requires physical access to the console and a floppy or CD drive, depending on which tool you choose. And it’s not easy, although it always work!
Offline NT Password & Registry Editor - Available as bootdisk or bootable CD, Offline NT Password and Registry Editor works to change or reset password of any users on Windows NT 3.51, NT 4, Windows 2000, Windows XP, Windows Server 2003, Vindows Vista 32 and 64 bit. It can also detect and offer to unlock locked or disabled user accounts.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
