SOURCE: Kitchenaid top load washer
you most likely have a broken motor coupling, remove the cabinet, then the pump and motor to expose the coupling.
SOURCE: Our KitchenAid KAWS850LE1 Washing machine will not drain or spin
you need to replace the lid switch
SOURCE: Washer not going through all cycles
You need to clean out your outlet filter; located below the big hose from the bottom of your tub. This needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain if the outlet is clogged.
SOURCE: my front load washing machine won't spin and drain the water
Check that it is actually heating the water in there. If the heating element has gone, then it will fill, then wait while it heats up the water needed - which it can't, so will just sit there full of water.
Usually involves taking the front off, which isn't easy.
Try it on a rinse and spin and see if it does anything, then you will know better what part is actually causing problems.
SOURCE: Hi, my kaws850lq1 washing machine
This can commonly be caused by a malfunctioning lid switch.
